How to stream data from IFC (Integrated Flash Controller) to DDR?
janarbek_matai
Hi All,
I am wondering is it possible to use IFC inteface in LS1088 to stream data to AOIP?
More specifically, can we stream data to DDR from an IFC interface?
Pavel
The LS2088a IFC and DDR is direct memory addresses areas.
Use memcpy for data transfers.
Often DMA is used for data transfers between different memory areas.
Pavel Chubakov
