We are using P2041 and I've been trying to initialize Fman Queue interface. When I try to schedule the queue with the command (0x41), I receive 0xF2 command result which should be 0xF0. When I check CMD_RSLT bits of QMAN_MCR register, there is no 0xF2.
Can you explain the meaning of 0xF2 command result?
Thank you,
I found the answer, it's because one or more FqID is scheduled before and its command is commited before altering.
