S12ZVL ESD TEST issue
zhanhui
Dear NXP engineer
       When we test ESD under the condition of 15KV air discharge, found the CAN didn't transmit CAN message in normal(it should transmit the message in cycle when normal work ), it continue stop work 118ms ,then recovery.
       For this situation ,could you help check and advise ?Thanks a lot!
