I changed a value in one of my startup files form 400 to 500 to increase my stack size and when I went to debug, a window kept popping up asking the question, "Erase to Unsecure?". I changed the number back and it is still doing the same thing. What can I do to fix this?
Hi Rody Braswell,
Can you tell where you modified this value and which MCU are you using?
Alexis Andalon
