imx6q - parallel RGB display support
Question asked by Asha Sampathkumar on Sep 24, 2018
Latest reply on Sep 24, 2018 by igorpadykov
Hi everyone ,
Our custom board is based on imx6q . We need to interface parallel RGB display to our custom board . We modified the below settings in dtsi file
mxcfb1: fb@0 {
        compatible = "fsl,mxc_sdc_fb";
        disp_dev = "lcd";
        interface_pix_fmt = "RGB24";
        default_bpp = <24>;
        int_clk = <0>;
        late_init = <0>;
        status = "disabled";
        mode_str="LCD"
lcd@0 {
compatible = "fsl,lcd";
ipu_id= <0>
disp_id = <0>
default_ifmt="RGB24"
pinctrl_names="default"
pinctrl-0= <&pinctrl_ipu1>
status = "okay"
&ldb {
    lvds-channel@0 {
        fsl,data-mapping = "spwg";
        fsl,data-width = <24>;
        primary;
        display-timings {
            native-mode = <&timing0>;
            timing0: hsd100pxn1 {
                clock-frequency = <51000000>;
                hactive = <1024>;
                vactive = <600>;
                hback-porch = <160>;
                hfront-porch = <80>;
                vback-porch = <19>;
                vfront-porch = <8>;
                hsync-len = <60>;
                vsync-len = <8>;
    lvds-channel@1 {
        fsl,data-width = <18>;
        display-timings {
            native-mode = <&timing1>;
            timing1: hsd100pxn1 {
                clock-frequency = <65000000>;
                hactive = <1024>;
                vactive = <768>;
                hback-porch = <220>;
                hfront-porch = <40>;
                vback-porch = <21>;
                vfront-porch = <7>;
                hsync-len = <60>;
                vsync-len = <10>;
then video/fbdev/mxc/mxc_lcdif.c added
static struct fb_videomode lcdif_modedb[] = {
    /*custom display */
    "LCD", 60, 720, 1280,12987, 72, 56, 38, 3, 128, 10,     // from custom LCD datasheet
    FB_SYNC_CLK_LAT_FALL,                                      //
    FB_VMODE_NONINTERLACED,
    0,},
Problem is there is no pixel clock generated (checked by probing disp0_clk line).
But in cat  /sys/kernel/debug/clk/ipu1_pclk0/clk_rate displays 77 MHZ
Is there any other setting missed ? Kindly help me in resolving this issue.
Asha
