Clicking on any value declared in a Freescale CodeWarrior v6.3 project in Assembly Language does not bring the option "Go to declaration of", that helps navigate in multiple source files projects.
The 'go to declaration of' uses the Eclipse Indexer. The Eclipse Indexer parses the source files (see Fixing the Eclipse Index | MCU on Eclipse ). The Eclipse indexer parser knows about C and C++ and other languages as Java, but not about assembly as there is no real standard for it. Therefore the assembly symbols are not parsed and available.
I hope this helps,
Erich
