I want to monitor the baby sitting inside the car using pressure mat (flex PCB ).
Please recommend me pressure sensors from NXP with low profile height ...
Dinesh Katkar
Hello Dinesh,
You can take a look here https://www.nxp.com/products/sensors/pressure-sensors:DRSNSPRSSR for the different pressure sensors that we have and the target applications that they are focused on; the device you select will depend on the pressure range you wish to measure.
Paulina
