gcm icv length
Question asked by Kevin Whitfield on Sep 20, 2018
Latest reply on Sep 27, 2018 by bpe
# AES GCM ICV
I've encountered an issue exercising the cipher-gcm sample under cryptodev-linux-1.8 of the 1703 SDK:  While performing a decryption with a full-sized ICV works, specifying shorter ICV values (by tweaking cao.len and cao.tag_len) does not consistently work across the documented range of 4-16 bytes.  More specifically:
  ICV Length      Result
  16                  SUCCEEDS
  15                  FAILS
  14                  SUCCEEDS
  13                  FAILS
  12                  SUCCEEDS
  11                  FAILS
  10                 SUCCEEDS
   9                  FAILS
   8                  SUCCEEDS
   7                  FAILS
   6                  SUCCEEDS
   5                  FAILS
   4                  SUCCEEDS
During the failures, a -EBADMSG failure is reported in the syslog after the caam driver detects an JRSTA_CCBERR_ERRID_ICVCHK error indication from the SEC:
Aug 22 17:40:07 c293pcie kernel: cryptodev: cipher-gcm[2479] (waitfor:256): error from async request: -74
Aug 22 17:40:07 c293pcie kernel: cryptodev: cipher-gcm[2479] (auth_n_crypt:681): cryptodev_cipher_decrypt: -74
