is there any Emulated EEPROM driver for LPC802
naveenkumar_b
I am using LPC802 16kb flash controller. I would like to retain and change few parameters by using configurator. I don't want to use external EEPROM. Is there any is there any Emulated EEPROM driver for LPC802 controller.
Naveen
kerryzhou
Hi Naveen Kumar,
    We have an application named as AN12125 Using LPC802 as I2C-bus EEPROM, this application will simulate the LPC802 chip as the eeprom, it also contains the code, it use the flash as the eeprom storage, just what you want to have, please download this application note.
Wish it helps you!
Kerry
kerryzhou
Hi Naveen Kumar,
Wish it helps you!
Kerry
biju_nair
This link seems broken. Any new link available ?
Regards, Biju
naveenkumar_b
