Unable to get Wi-Fi working properly on Android Oreo on i.Mx6 SabreSD
Question asked by susangrace rapaka on Sep 19, 2018
Latest reply on Sep 20, 2018 by jimmychan
Hi ,
I am working on Android Oreo with Custom Wi-Fi driver on i.Mx6 SabreSD board.  I am unable to get Wi-Fi Working properly, after getting Wi-Fi scan results on GUI, Wi-Fi is going off.I am observering some issue with P2P. I have disabled P2P in android.config file but still I am seeing P2P enabled prints.
How to disable P2P on android OREO?
The logs are,
WifiStateMachine: Before StartMonitoring***************** mInterfaceNmae is wlan0
wpa_supplicant: wpa_supplicant v2.7-devel-8.0.0
wpa_supplicant: random: Added entropy from /data/misc/wifi/entropy.bin (own_pool_ready=2)
wpa_supplicant: random: Trying to read entropy from /dev/random
wpa_supplicant: Get randomness: len=20 entropy=1
wpa_supplicant: random: Updated entropy file /data/misc/wifi/entropy.bin (own_pool_ready=2)
wpa_supplicant: Global control interface '@android:wpa_wlan0'
wpa_supplicant: Using Android control socket 'wpa_wlan0'
wpa_supplicant: Initing hidl control
wpa_supplicant: Processing hidl events on FD 5
wpa_supplicant: Successfully initialized wpa_supplicant
wpa_supplicant: ****** in wpa_supplicant_init_iface******
wpa_supplicant: Initializing interface 'wlan0' conf '/vendor/etc/wifi/wpa_supplicant.conf' driver 'nl80211' ctrl_interface 'N/A' bridge 'N/A'
wpa_supplicant: Configuration file '/vendor/etc/wifi/wpa_supplicant.conf' -> '/vendor/etc/wifi/wpa_supplicant.conf'
wpa_supplicant: Reading configuration file '/vendor/etc/wifi/wpa_supplicant.conf'
SupplicantP2pIfaceHal: IServiceNotification.onRegistration for: android.hardware.wifi.supplicant@1.0::ISupplicant, default preexisting=false
system_server: Looking for service android.hardware.wifi.supplicant@1.0::ISupplicant/default
wpa_supplicant: ctrl_interface='wlan0'
wpa_supplicant: update_config=1
wpa_supplicant: eapol_version=1
wpa_supplicant: ap_scan=1
wpa_supplicant: fast_reauth=1
wpa_supplicant: pmf=1
wpa_supplicant: uuid=12345678-9abc-def0-1234-56789abcdef0
wpa_supplicant: device_name='RS9113_n-Link'
wpa_supplicant: manufacturer='Redpine Signals INC'
wpa_supplicant: model_name='OneBox-Mobile'
wpa_supplicant: model_number='9113'
wpa_supplicant: serial_number='03'
wpa_supplicant: os_version=01020300
wpa_supplicant: config_methods='display push_button keypad'
wpa_supplicant: persistent_reconnect=1
wpa_supplicant: p2p_disabled=1
wpa_supplicant: Line: 24 - start of a new network block
wpa_supplicant: ssid - hexdump(len=12): 52 45 44 50 49 4e 45 5f 4f 50 45 4e
wpa_supplicant: key_mgmt: 0x4
wpa_supplicant: priority=2 (0x2)
wpa_supplicant: Line: 31 - start of a new network block
wpa_supplicant: ssid - hexdump(len=15): 52 45 44 50 49 4e 45 5f 41 50 5f 43 43 4d 50
wpa_supplicant: key_mgmt: 0x2
wpa_supplicant: PSK (ASCII passphrase) - hexdump(len=8): [REMOVED]
wpa_supplicant: priority=1 (0x1)
system_server: Starting thread pool.
wpa_supplicant: PSK (from passphrase) - hexdump(len=32): [REMOVED]
wpa_supplicant: Priority group 2
wpa_supplicant:    id=0 ssid='REDPINE_OPEN'
wpa_supplicant: Priority group 1
wpa_supplicant:    id=1 ssid='REDPINE_AP_CCMP'
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:1
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:5
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:2
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:4
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:10
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:8
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:9
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:6
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:13
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:11
wpa_supplicant: nl80211: Supported cipher 00-0f-ac:12
wpa_supplicant: nl80211: Driver-advertised extended capabilities (default) - hexdump(len=8): 00 00 00 00 00 00 00 40
wpa_supplicant: nl80211: Driver-advertised extended capabilities mask (default) - hexdump(len=8): 00 00 00 00 00 00 00 40
wpa_supplicant: nl80211: use P2P_DEVICE support
wpa_supplicant: nl80211: interface wlan0 in phy phy5
wpa_supplicant: nl80211: Set mode ifindex 9 iftype 2 (STATION)
wpa_supplicant: nl80211: Subscribe to mgmt frames with non-AP handle 0xac92d7a8
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0104
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=040a
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=040b
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=040c
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=040d
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=090a
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=090b
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=090c
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=090d
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0409506f9a09
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=7f506f9a09
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0801
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=06
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0a07
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0a11
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0a1a
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=1101
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=1102
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0505
wpa_supplicant: nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0xac92d7a8 match=0500
wpa_supplicant: rfkill: Cannot open RFKILL control device
wpa_supplicant: nl80211: RFKILL status not available
wpa_supplicant: netlink: Operstate: ifindex=9 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
wpa_supplicant: Add interface wlan0 to a new radio phy5
wpa_supplicant: nl80211: Regulatory information - country=00
wpa_supplicant: nl80211: 2402-2472 @ 40 MHz 20 mBm
wpa_supplicant: nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
wpa_supplicant: nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
wpa_supplicant: nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
wpa_supplicant: nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
wpa_supplicant: nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
wpa_supplicant: nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
wpa_supplicant: nl80211: 57240-63720 @ 2160 MHz 0 mBm
wpa_supplicant: nl80211: Added 802.11b mode based on 802.11g information
wpa_supplicant: wlan0: Own MAC address: 00:23:a7:90:3c:a0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=4 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wpa_driver_nl80211_set_key: ifindex=9 (wlan0) alg=0 addr=0x0 key_idx=5 set_tx=0 seq_len=0 key_len=0
wpa_supplicant: wlan0: RSN: flushing PMKID list in the driver
wpa_supplicant: nl80211: Flush PMKIDs
wpa_supplicant: TDLS: TDLS operation not supported by driver
wpa_supplicant: TDLS: Driver uses internal link setup
wpa_supplicant: TDLS: Driver does not support TDLS channel switching
wpa_supplicant: WPS: Converting display to virtual_display for WPS 2.0 compliance
wpa_supplicant: WPS: Converting push_button to virtual_push_button for WPS 2.0 compliance
wpa_supplicant: wlan0: WPS: UUID based on configuration: 12345678-9abc-def0-1234-56789abcdef0
wpa_supplicant: EAPOL: SUPP_PAE entering state DISCONNECTED
wpa_supplicant: EAPOL: Supplicant port status: Unauthorized
wpa_supplicant: nl80211: Skip set_supp_port(unauthorized) while not associated
wpa_supplicant: EAPOL: KEY_RX entering state NO_KEY_RECEIVE
wpa_supplicant: EAPOL: SUPP_BE entering state INITIALIZE
wpa_supplicant: EAP: EAP entering state DISABLED
wpa_supplicant: global ctrl interface @android:wpa_wlan0 matches ctrl interface wlan0 - do not open per-interface ctrl interface
wpa_supplicant: Registering interface to hidl control: wlan0
wpa_supplicant: Registering network to hidl control: 0
wpa_supplicant: Registering network to hidl control: 1
wpa_supplicant: wlan0: Added interface wlan0
wpa_supplicant: wlan0: State: DISCONNECTED -> DISCONNECTED
wpa_supplicant: nl80211: Set wlan0 operstate 0->0 (DORMANT)
wpa_supplicant: netlink: Operstate: ifindex=9 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
wpa_supplicant: random: Got 20/20 bytes from /dev/random
wpa_supplicant: Get randomness: len=20 entropy=0
wpa_supplicant: RTM_NEWLINK: ifi_index=9 ifname=wlan0 operstate=2 linkmode=1 ifi_family=0 ifi_flags=0x3 ([UP])
SupplicantStaIfaceHal: +++++++ in initSupplicantStaIface
SupplicantStaIfaceHal: +++++++ in initSupplicantStaIface try
SupplicantStaIfaceHal: +++++++ in initSupplicantStaIface before  addALL
SupplicantStaIfaceHal: +++++++ in Mutable 2
SupplicantP2pIfaceHal: entering getInterface()
SupplicantStaIfaceHal: +++++++ in initSupplicantStaIface try1
SupplicantP2pIfaceHal: initSupplicantP2pIface got null iface
SupplicantP2pIfaceHal: initalizing ISupplicantIfaces failed.
wpa_supplicant: *****IN wpa_supplicant_get_iface***
wpa_supplicant: IN wpa_supplicant_get_iface ifname is wlan0
SupplicantStaIfaceHal: +++++++ iface is ISupplicantIface android.hardware.wifi.supplicant@1.0::ISupplicantStaIface@Proxy
SupplicantStaIfaceHal: Failed to get ISupplicantIface android.hardware.wifi.supplicant@1.0::ISupplicantStaIface@Proxy
SupplicantStaIfaceHal: Failed to get supplicantIface.value android.hardware.wifi.supplicant@1.0::ISupplicantStaIface@Proxy
SupplicantStaIfaceHal: +++++++ ifaceName.value wlan0
SupplicantStaIfaceHal: Completed initialization of ISupplicant interfaces.
WifiMonitor: +++++++ in startMonitoring iface is wlan0
WifiMonitor: +++++++ after startMonitoring ifwlan0
WifiMonitor: +++++++ inbroadcastSupplicantConnectionEvent wlan0
SupplicantStaIfaceHal: +++++++++++++++++++++In getMacAddress
WifiConfigManager: Legacy store files not found. No migration needed!
WifiStateMachine: Setting OUI to DA-A1-19
WifiHAL : Sending mac address OUI
WifiHAL : failed to set scanning mac OUI; result = -95
WifiVendorHal: setScanningMacOui(l.1452) failed {.code = ERROR_NOT_AVAILABLE, .description = }
WifiHAL : Failed to register debug response; result = -95
android.hardware.wifi@1.0-service: Failed to get driver version: SUCCESS
WifiVendorHal: requestChipDebugInfo(l.1734) failed {.code = ERROR_NOT_AVAILABLE, .description = failed to get driver version}
WifiVendorHal: Driver: null Firmware: null
WifiVendorHal: getRingBufferStatus(l.1811) failed {.code = ERROR_NOT_AVAILABLE, .description = }
WifiDiags: no ring buffers found
WifiHAL : Start get packet fate command
WifiHAL : createRequest Monitor packet fate request
WifiHAL : Failed to register get pkt fate response; result = -95
WifiVendorHal: startPktFateMonitoring(l.1897) failed {.code = ERROR_NOT_AVAILABLE, .description = }
WifiDiags: Failed to start packet fate monitoring
wpa_supplicant: wpa_driver_nl80211_driver_cmd: failed to issue private command: BTCOEXSCAN-STOP
SupplicantStaIfaceHal: ISupplicantStaIface.setBtCoexistenceScanModeEnabled failed: FAILURE_UNKNOWN,
wpa_supplicant: wpa_driver_nl80211_driver_cmd: failed to issue private command: RXFILTER-STOP
SupplicantStaIfaceHal: ISupplicantStaIface.stopRxFilter failed: FAILURE_UNKNOWN,
wpa_supplicant: wpa_driver_nl80211_driver_cmd: failed to issue private command: SETSUSPENDMODE 0
SupplicantStaIfaceHal: ISupplicantStaIface.setSuspendModeEnabled failed: FAILURE_UNKNOWN,
WifiNative-wlan0: +++++++++++++++++++++In setPowersave in wifiNative.java
SupplicantStaIfaceHal: +++++++++++++++++++++In setPowerSave
SupplicantStaIfaceHal: In try+++++++++++++++++++++In setPowerSave
audio_hw_primary: do_out_standby... -1362246336
hw-IPCThreadState: binder thread pool (1 threads) starved for 2045 ms
DHCP    : +++++++ in ifc_init
CommandListener: argv[0]=interface argv[1] = getcfg argv[2]=wlan0
DHCP    : +++++++ in ifc_get_info
DHCP    : +++++++ in ifc_get_hwaddr
SupplicantStaIfaceHal: +++++++++++++++++++++In enableAutoReconnect
RttService: SCAN_AVAILABLE : 3
WifiScanningService: wifi driver loaded with scan capabilities: max buckets=16
RttService: DefaultState got{ when=0 what=160512 target=com.android.internal.util.StateMachine$SmHandler }
CommandListener: Setting iface cfg
wificond: New interface event callback registered
DHCP    : +++++++ in inint_sockaddr
RttService: EnabledState got{ when=0 what=160516 obj=android.net.wifi.IClientInterface$Stub$Proxy@326922e target=com.android.internal.util.StateMachin}
WifiP2pService: Unable to change interface settings: java.lang.IllegalStateException: command '69 interface setcfg p2p0 0.0.0.0 0 broadcast up' failed'
WifiP2pService: Callling startMonitoring in P2P
WifiP2pMonitor: startMonitoring(p2p0)
WifiVendorHal: getSupportedFeatureSet(l.898) failed {.code = ERROR_NOT_AVAILABLE, .description = }
WifiVendorHal: getSupportedFeatureSet(l.904) failed {.code = ERROR_NOT_AVAILABLE, .description = }
HalDeviceManager: +++++++ in getAllChipInfo
WifiManager: In get Scanresults
android.hardware.wifi@1.0-service: +++++++ in getAvailable ModesInternal
android.hardware.wifi@1.0-service: getAvailable ModesInternal p2p
WifiManager: In getConfiguredNetworks
android.hardware.wifi@1.0-service: +++++++ in getStaIfaceNames
HalDeviceManager: +++++++ before WifiIfaceInfo
HalDeviceManager: +++++++ calling getStaIface
HalDeviceManager: +++++++ statusOk
HalDeviceManager: +++++++ ifaceName = wlan0
HalDeviceManager: +++++++ iface = android.hardware.wifi@1.0::IWifiStaIface@Proxy
HalDeviceManager: +++++++ ifaceInfo.iface = android.hardware.wifi@1.0::IWifiStaIface@Proxy
HalDeviceManager: +++++++ ifaceInfo.name = wlan0
android.hardware.wifi@1.0-service: +++++++ in getP2pIfaceNames
android.hardware.wifi@1.0-service: +++++++ in getP2pIfaceNamesInternal
HalDeviceManager: +++++++ before P2p
WifiConnectivityHelper: Firmware supported feature set: 19
WifiConnectivityHelper: Firmware roaming is not supported
WifiStateMachine: disconnectedstate enter
WificondScannerImpl: +++++++ in startsingle scan
WificondControl: +++++SUSAN start scan
wificond: In wificond Scan
wificond: In wificond i value is0
wificond: In wificond ssids.size  is1
wificond: In wificond SSID[i]0
wificond: In wificond before trigger_scan
wificond: In netlink SendMessageAndGetAckOrError
BatteryStatsService: no controller energy info supplied
WifiManager: return list
WifiSettings: onAccessPointsChanged (WifiTracker) callback initiated
WifiP2pMonitor: setMonitoring(p2p0)
WifiP2pMonitor: startMonitoring(p2p0) failed!
WifiP2pService: P2p socket connection failed
Here I am seeing Wi-Fi is getting OFF in GUI after this
Can anyone help me to resolve this
Susan
