Flash interface initialization
Question asked by ranshalit on Sep 19, 2018
Latest reply on Sep 24, 2018 by LPCX presso support
Hello
I would please like to ask:
On IDE user guide it says that flash is programmed on debug session too.
Is it that the flash interface is initialized with the FCB block  parameters using the already programmed application in flash (which contains FCB), or is it initialized because of flash driver support in MCUXpresso IDE?
Or is it that the answer to this question depends on how we set the MCU memory map inside the IDE (adding driver name on the flash line or deleting the driver name)?
I also seen the following question and the answer there confused me on this topic
Quad SPI flash support on MCUXpresso IDE v10.1.1 for the iMX.RT1050?
Another question is what the difference between gui programmer and simple press of debug button?
Thank you
ranran
