Please refer to the reference manual of i.MX6ULL(https://www.nxp.com/docs/en/reference-manual/IMX6ULLRM.pdf). In the page 3126, there's a description about MCLK Select as follows.
NOTE: Depending on the device, some Master Clock options might not be available. See the chip specific
information for the meaning of each option.
00 Master Clock (MCLK) 1 option selected.
01 Master Clock (MCLK) 1 option selected.
10 Master Clock (MCLK) 2 option selected.
11 Master Clock (MCLK) 3 option selected.
Would someone please explain the meaning of each option (1,2,3)?, or please let me know where the chip specific information is?
Thank you very much in advance.
makoto
Solved! Go to Solution.
Hi Makoto
options are the same as for i.MX6UL :
Hi Makoto
Hi Igor,
I got it. Thank you very much for your quick and clear answer!
makoto
