[MPC5748G] Use OpenSDA to debug 2nd and 3rd cores
travis_kuo
HI,
I tried to debug 2nd/3rd core of MPC5748G on the MPC5748G EVB but didn't get success.
My IDE is S32DS.
May I know if it's possible to do so? If yes would you please provide hints?
martin_kovar
first of all, please ensure, you have correctly downloaded source code for all cores. To achieve this, you can use LaunchGroup option. Please see the figure below:
After all code is downloaded, you can see the figure below:
You can switch the cores by clicking the main function as you can see in the figure above.
Martin
martin_kovar
Martin
