I am working on LPC1769, Keil IDE and using RL Tcpnet. I am unable to send emails via SMTP. I am either getting a SMTP timeout or SMTP error. i tried using port 25 and port 80 but it didnt work.
Please suggest.
Hi Zaid Shaikh,
I'd highly recommend you to visualize the Ethernet communication via the Wireshark and share it, as it will help us to locate the root cause.
TIC
Hi jeremyzhou
Thanks for your concern, ill check on wireshark and let u know.
