FRDM-K64F fail timeout
ricardo_zamorad
Compré una FRDM-K64F. Cuando la conecto a mi computadora, después de unos segundos se desconecta y vuelve a conectar y muestra un error de timeout. No me permite hacer nada porque se desconecta repetidamente.
victorjimenez
Hello Ricardo,
Please follow the next steps to update your FRDM-K64F firmware with JLINK.
  1. Unplug the board, press the reset button and hold on it, then plug the cable to the board in J26, release the button.
  2. You will find the board as a disc named "BOOTLOADER".
  3. Download the JLINK driver and install it. Link.
  4. Download the JLINK firmware for the FRDM-K64F. Link.
  5. Send the bin file to your board disc "BOOTLOADER".
  6. Once it finished copying the file unplug the cable and plug it again.
Hope it helps!
Victor.
