hi,
platform:ls1012afrwy
lsdk:lsdk-18.06
command:flex-builder -c apps -a arm64 -m ls1012afrwy
lL/home/forlinx/flexbuild/build/rfs/rootfs_ubuntu_bionic_arm64/lib/aarch64-linux-gnu ovn/lib/.libs/libovn.a ovsdb/.libs/libovsdb.a lib/.libs/libopenvswitch.a -lcrypto -ldpdk -latomic -lpthread -lrt -lm -ldl -lnuma -lssl
lib/.libs/libopenvswitch.a(stream-ssl.o): In function `do_ssl_init':
flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:954: undefined reference to `OPENSSL_init_ssl'
flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:955: undefined reference to `OPENSSL_init_ssl'
flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:997: undefined reference to `TLS_method'
flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:1008: undefined reference to `SSL_CTX_set_options'
lib/.libs/libopenvswitch.a(stream-ssl.o): In function `ssl_do_tx':
flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:675: undefined reference to `SSL_get_state'
flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:677: undefined reference to `SSL_get_state'
lib/.libs/libopenvswitch.a(stream-ssl.o): In function `ssl_recv':
flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:642: undefined reference to `SSL_get_state'
flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:644: undefined reference to `SSL_get_state'
lib/.libs/libopenvswitch.a(stream-ssl.o):/home/forlinx/flexbuild/packages/apps/ovs-dpdk/lib/stream-ssl.c:677: more undefined references to `SSL_get_state' follow
I tried docker and ubuntu18, but all failed.
How should i solve this problem?
Hello li zuobin,
Please execute the command first before building ovs-dpdk.
flex-builder -c openssl -a arm64
TIC
