LPC824 SPI Sample Code with MCUXpresso
ellenlin
Now i am using LPC824 Demo_Example from SDK_2.4.2_LPCXpresso824MAX .
But i don't understand how to realize the demo_example . Following is all example i wanna know ,
How to setting the EVM ? What tools i have to use it ? thanks !!
soledad
Select all spi examples and click Finish in order to import to the workspace.
After do that, you can find a readme document under doc folder that you can use as reference.
I hope this helps,
Sol
ellenlin
Dear Soledad ,
   i has already download 2 evm with SPI_Interrupt_Master ( Debug Mode ) & SPI_Interrupt_Slave ( Free RUN )
   but transfer date fail , what is happening ?
   i need you suggestion to solve this and i can keep going my application , thanks a lot !!
