can anyone recommend a replacement for the ethernet jack J13 in the Freedom K66F board?
lum
the specified UDE part number RB1-125B1F1A for J13, the ethernet connector with magnetics, is nowhere to be found.  Can anyone recommend a compatible alternative?
Hui_Ma
Please check ARJE-0034 (RJ45, Single Port, Tap Up, SMD, 100 Base-T) as a replacement.
Wish it helps.
Mike
