how to use lauterbach script?
allenlw
There are some examples in the MPC5 software example list that use a form called lauterbach script , there are address and some 64bit value in there , I wonder if there are more convenient ways to use this script  other than reading it as a text.
If there are better ways , please let me know , thanks for your help.
petervlna
I use file\run script...  to run demo script, it shows file C:\T32\quad\c55fm5746r.bin not found.
Is it my action wrong, or is my trace32 got a wrong version or else?
Everything is OK, You just have to change in script the path for binary files.
It looks like it is in different directory than one that script use.
Just change C:\T32\quad\c55fm5746r.bin in script to directory where your c55fm5746r.bin is in your PC.
Peter
petervlna
HI,
Lauterbach scripts are intended to be used by lauterbach debuggers.
64-bit means that this script is used for DCF records update.
Peter
allenlw
hi, peter
I have a  lauterbach debugger.
Do you know how to fix this?
petervlna
Peter
allenlw
Tks peter, I finally got it right.
