How to access recorded audio using SAI interface of MIMXRT1050_EVK
ajith_kumars
I want to process the recorded audio, using SAI interface.
The source of the example code I am using is attached.
Below is the part of code I am interested in
    while(1)
        if(emptyBlock > 0)
            xfer.data = Buffer + rx_index * BUFFER_SIZE;
            xfer.dataSize = BUFFER_SIZE;
            if(kStatus_Success == SAI_TransferReceiveNonBlocking(DEMO_SAI, &rxHandle, &xfer))
                rx_index++;
            if(rx_index == BUFFER_NUMBER)
                rx_index = 0U;
        if(emptyBlock < BUFFER_NUMBER)
            xfer.data = Buffer + tx_index * BUFFER_SIZE;
            if(kStatus_Success == SAI_TransferSendNonBlocking(DEMO_SAI, &txHandle, &xfer))
                tx_index++;
            if(tx_index == BUFFER_NUMBER)
                tx_index = 0U;
Does xfer.data contain the audio data?
If I just want to record the data and do not want to play it back is it safe to assume that I can comment out the
if(emptyBlock < BUFFER_NUMBER) block?
Note: I want to feed the audio data into another function which does further processing.
weidong_sun
Hi, Ajith,
   See below, please!
(1)Does xfer.data contain the audio data?
Yes.
(2)if(emptyBlock < BUFFER_NUMBER) block?
Yes , the statement and those behind it are all for playback, you can comment them if you don't want to play back at the same time.
Try it ,please!
Have a nice day!
TIC Weidong Sun
