how to implement periodic using any timers from very low power mode for s32K14x?
You can use either RTC (alarm interrupt) or LPTMR.
An RTC example without VLPS can be found here:
How to use RTC module with no SDK?
Example S32K144 CMP Round-robin S32DS2.0 is using LPTMR that triggers CMP.
