how can I change the ATR of a jcop21-36 smartcard?
gse49
I need a solution to modify the ATR for jcop21-36 java smartcard.
someone told me, i need script with APDU command, where can I get this?
thanks a lot
best regards
Jonathan_Iglesias
Dear Daniel Bachmann,
Hope you are doing great, as you may know the JCOP information is secured under NDA (Non Disclosure Agreement) this means that the information about JCOP should be delivered only to customers with active signed NDA for JCOP also using a secured communication channel, please contact your local or closest NXP office or certified distributor in order to get access to the information that can help you solve your question.
My apologies for the inconvenience this means to you and your project.
Have a great day !
Jonathan
