upgrade from k60 to k66
TJ
Our company is evaluating upgrading from MK60FN1M0VLQ12 to MK66FN2M0VLQ18 and I was reading this document
https://www.nxp.com/docs/en/data-sheet/K66P144M180SF5V2.pdf
The document states " These devices maintain hardware and software compatibility with the existing Kinetis family." does that mean that the bootloader for MK60FN1M0VLQ12 would work for MK66FN2M0VLQ18 ?
Could someone please help me out here, I do not know who else to ask!
Cheers
Robin_Shen
Hi TJ,
No. You may need to compare the difference of memory map between two MCU.
In fact you can direct download the latest MCUBOOT for MK66FN2M0xxx18.
The documents can be found in it's folder.(...\MK66FN2M0xxx18\middleware\mcu-boot\doc)
Robin
Robin_Shen
Hi TJ,
Robin
TJ
Thank you very much Robin for the reply! Much appreciated.
