导入例程,编译出现错误
Did you install the SDK for the JN-AN-1174? JN-SW-4163
Mario
Description Resource Path Location TypeProgram "make" not found in PATH venes_a_fbl_HASCO_RDRA_S32_Z4 C/C++ Problem
请问这种问题怎么解决
Please look at the next community Beyond Studio Common Errors
我是把workspace建在了D盘,改变了默认安装路径,导致报错,现在如何修改呢?
而且我在properties->c/c++build->environment加入了make.exe的现有路径,error依然存在
Is it possible that you could submit your question in English?
I built workspace on D disk, changed the default installation path, resulting in error, how to modify it now?
And I added the existing path to make. exe in properties - > c/c++ build - > environment, and errors still exist.
Please look at the next community post
I know the reason,so ,how can i deal with it
?reinstall????
You need the files in the next path C:\NXP\bstudio_nxp\workspace
i reinstall the S32 design for power2017R1,and set all the install path following Default installation path,but error exsists still,can you offer some useful suggestion ?
I am not following. Did you reinstall the S32 Design?
Are not you working with Beyond Studio IDE?
IEEE® 802.15.4 for JN516x and JN517x
Mario
