LS1043A-CONNECT
LS1043A-CONNECT
肆加贰
We use the core board of the LS1043A chip. After power-on, the power supply part is normal. After connecting the CodeWarrior TAP and clicking the A button in the figure, the error in the B area will appear. Our hardware has an error in design, CFG_RCW_SRC0-8 floating, will this hardware error cause this error? Is it possible to modify the Target Initialization file so that the debugger can connect successfully and then debug normally?
