MQX debugging error
MQX debugging error
davidzhou
Contributor V
I have Code Warrior 10.6.4.FSL_b06015 license, and MQX4.2 installed with K60 tower.
Now I cannot debug all my previously debug-able projects. If I create new project, it still cannot debug.
But if I change the debugger setting of OS Awareness to None, then it can debug.
Is this a license issue or some settings are missing?
Thank you,
David
Tags (2)
davidzhou
Contributor V
I recreated an example, with MQX 4.2. It is able to debug. So it seems not related to MQX. Maybe the project data or settings are corrupted.
David
ZhangJennie
Hi David,
So you have solved your problem. Thanks for the updating.
Best Regards
Jennie Zhang
