Using Hyperflash as Data-Storage
Question asked by Masmiseim on Aug 28, 2018
Latest reply on Sep 18, 2018 by Masmiseim
mimx-rt1050-evk
Are there any examples around how to use the Hyperflash as Data-Storage while simultaneously running code out of it?
I’m aware that the SDK has some examples for using the flexSPI with NOR and Hyperflash, but this example run out of the On-Chip-RAM.
I believe with running out of the Hyperflash things are a bit different. The Interface should be already initialized by the On-Chip-Bootloader. The routines doing the actual access should be running out of RAM (ITCM) … anything else?
Thanks and Regards
