Hello everyone,
I am having trouble building QorIQ SDK for LS1046A-RDB. I followed the instructions present in "QorIQ SDK v2.0-1703 Documentation" and ended up getting following errors when running bitbake. Can some body help me?
umkhan@umkhan-VirtualBox:~/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/build_ls1046ardb$ bitbake --help Traceback (most recent call last): File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/bin/bitbake", line 31, in <module> import bb File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/__init__.py", line 77, in <module> from bb import fetch2 as fetch File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 37, in <module> import bb.persist_data, bb.utils File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/persist_data.py", line 35, in <module> from pysqlite2 import dbapi2 as sqlite3 ImportError: No module named pysqlite2 /home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/event.py:118: RuntimeWarning: Parent module 'bb' not found while handling absolute import from bb.msg import BBLogFormatter Error in atexit._run_exitfuncs: Traceback (most recent call last): File "/opt/python-2.7.6/lib/python2.7/atexit.py", line 24, in _run_exitfuncs func(*targs, **kargs) File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/event.py", line 118, in print_ui_queue from bb.msg import BBLogFormatter File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/__init__.py", line 77, in <module> from bb import fetch2 as fetch File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 37, in <module> import bb.persist_data, bb.utils File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/persist_data.py", line 35, in <module> from pysqlite2 import dbapi2 as sqlite3 ImportError: No module named pysqlite2 Error in sys.exitfunc: Traceback (most recent call last): File "/opt/python-2.7.6/lib/python2.7/atexit.py", line 24, in _run_exitfuncs func(*targs, **kargs) File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/event.py", line 118, in print_ui_queue from bb.msg import BBLogFormatter File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/__init__.py", line 77, in <module> from bb import fetch2 as fetch File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 37, in <module> import bb.persist_data, bb.utils File "/home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/persist_data.py", line 35, in <module> from pysqlite2 import dbapi2 as sqlite3 ImportError: No module named pysqlite2
I do following steps prior to running bitbake:
umkhan@umkhan-VirtualBox:~/QorIQ/QorIQ-SDK-V2.0-20160527-yocto$ ./sources/meta-freescale/scripts/host-prepare.sh Verifying sudo permission to execute apt-get command. Now we're going to install all the other development packages needed to build Yocto, please wait Reading package lists... Done Building dependency tree Reading state information... Done build-essential is already the newest version. chrpath is already the newest version. diffstat is already the newest version. gawk is already the newest version. screen is already the newest version. texinfo is already the newest version. tofrodos is already the newest version. xterm is already the newest version. xz-utils is already the newest version. libstring-crc32-perl is already the newest version. socat is already the newest version. libsdl1.2-dev is already the newest version. unzip is already the newest version. vim-common is already the newest version. git-core is already the newest version. wget is already the newest version. The following packages were automatically installed and are no longer required: ack-grep android-tools-adb android-tools-fastboot at binutils-aarch64-linux-gnu binutils-arm-linux-gnueabihf binutils-powerpc-linux-gnu cpanminus cpp-4.8-aarch64-linux-gnu cpp-4.8-arm-linux-gnueabihf cpp-4.8-powerpc-linux-gnu cpp-aarch64-linux-gnu cpp-arm-linux-gnueabihf cpp-powerpc-linux-gnu dctrl-tools debian-archive-keyring debootstrap devscripts distro-info distro-info-data gcc-4.8-aarch64-linux-gnu-base gcc-4.8-arm-linux-gnueabihf-base gcc-4.8-powerpc-linux-gnu-base gnome-settings-daemon lib64asan0-powerpc-cross lib64atomic1-powerpc-cross lib64gcc-4.8-dev-powerpc-cross lib64gcc1-powerpc-cross lib64gomp1-powerpc-cross liba52-0.7.4 libaacs0 libaliased-perl libalien-wxwidgets-perl libappindicator1 libasan0-armhf-cross libasan0-powerpc-cross libass4 libatomic1-arm64-cross libatomic1-armhf-cross libatomic1-powerpc-cross libavcodec54 libavformat54 libavutil52 libbasicusageenvironment0 libbluray1 libc6-arm64-cross libc6-armel-armhf-cross libc6-armhf-cross libc6-dev-arm64-cross libc6-dev-armel-armhf-cross libc6-dev-armhf-cross libc6-dev-powerpc-cross libc6-dev-ppc64-powerpc-cross libc6-powerpc-cross libc6-ppc64-powerpc-cross libcapture-tiny-perl libcddb2 libchromaprint0 libclass-adapter-perl libclass-inspector-perl libclass-unload-perl libclass-xsaccessor-perl libcommon-sense-perl libcpan-distnameinfo-perl libcpan-meta-check-perl libcpan-meta-perl libcpan-meta-requirements-perl libcrystalhd3 libdbd-sqlite3-perl libdbi-perl libdc1394-22 libdca0 libdebug-client-perl libdevel-dumpvar-perl libdevel-refactor-perl libdirac-encoder0 libdirectfb-1.2-9 libdistro-info-perl libdvbpsi8 libdvdnav4 libdvdread4 libebml4 libenca0 libexporter-lite-perl libfaad2 libfile-find-rule-perl libfile-homedir-perl libfile-next-perl libfile-pushd-perl libfile-remove-perl libfile-sharedir-perl libfile-slurp-perl libfile-which-perl libgcc-4.8-dev-arm64-cross libgcc-4.8-dev-armhf-cross libgcc-4.8-dev-powerpc-cross libgcc1-arm64-cross libgcc1-armhf-cross libgcc1-powerpc-cross libgnutls28 libgomp1-arm64-cross libgomp1-armhf-cross libgomp1-powerpc-cross libgroupsock1 libgsm1 libhogweed2 libindicator7 libio-stringy-perl libipc-run3-perl libiso9660-8 libitm1-arm64-cross libjs-jquery libjson-perl libjson-xs-perl libkate1 liblivemedia23 liblocal-lib-perl liblocale-msgfmt-perl libmad0 libmatroska6 libmodplug1 libmodule-cpanfile-perl libmodule-manifest-perl libmodule-metadata-perl libmodule-starter-perl libmp3lame0 libmpcdec6 libmpeg2-4 libnumber-compare-perl libopenjpeg2 libopus0 liborlite-migrate-perl liborlite-perl libpadwalker-perl libparams-util-perl libparse-cpan-meta-perl libparse-debcontrol-perl libparse-errorstring-perl-perl libparse-exuberantctags-perl libpath-class-perl libpod-abstract-perl libpod-pom-perl libpod2-base-perl libpostproc52 libppi-perl libppix-editortools-perl libppix-regexp-perl libprobe-perl-perl libproxy-tools libpython-dev libpython2.7-dev libqgsttools-p1 libqpdf13 libqt5multimediawidgets5 libresid-builder0c2a libschroedinger-1.0-0 libsdl-image1.2 libsfasan0-armhf-cross libsfatomic1-armhf-cross libsfgcc-4.8-dev-armhf-cross libsfgcc1-armhf-cross libsfgomp1-armhf-cross libsidplay2 libsort-versions-perl libssh2-1 libstring-shellquote-perl libswscale2 libtar0 libtask-weaken-perl libtemplate-tiny-perl libtext-diff-perl libtext-findindent-perl libtext-glob-perl libtext-patch-perl libtie-ixhash-perl libtry-tiny-perl libts-0.0-0 libtwolame0 libupnp6 libusageenvironment1 libva-x11-1 libva1 libvcdinfo0 libvlc5 libvlccore7 libwx-perl libwx-perl-processstream-perl libwx-scintilla-perl libwxbase2.8-0 libwxbase2.8-dev libwxbase3.0-0 libwxgtk-media2.8-0 libwxgtk-media2.8-dev libwxgtk2.8-0 libwxgtk2.8-dev libx264-142 libxcb-composite0 libxcb-xv0 libxdelta2 libxvidcore4 libzvbi-common libzvbi0 linux-headers-4.4.0-124 linux-headers-4.4.0-124-generic linux-headers-4.4.0-31 linux-headers-4.4.0-31-generic linux-headers-4.4.0-98 linux-headers-4.4.0-98-generic linux-image-4.4.0-124-generic linux-image-4.4.0-31-generic linux-image-4.4.0-98-generic linux-image-extra-4.4.0-124-generic linux-image-extra-4.4.0-31-generic linux-image-extra-4.4.0-98-generic linux-libc-dev-arm64-cross linux-libc-dev-armhf-cross linux-libc-dev-powerpc-cross pbuilder pbzip2 preview-latex-style pristine-tar python2.7-dev python3-magic quilt texlive texlive-bibtex-extra texlive-latex-extra texlive-latex-extra-doc texlive-math-extra texlive-pictures texlive-pictures-doc tsconf ubuntu-device-flash vlc-data wx-common wx2.8-headers xdelta xmlto xsltproc Use 'apt-get autoremove' to remove them. The following packages will be REMOVED: gcc-4.8-aarch64-linux-gnu gcc-aarch64-linux-gnu The following NEW packages will be installed: gcc-multilib 0 upgraded, 1 newly installed, 2 to remove and 0 not upgraded. Need to get 0 B/1,024 B of archives. After this operation, 13.5 MB disk space will be freed. Do you want to continue? [Y/n] Y (Reading database ... 617615 files and directories currently installed.) Removing gcc-aarch64-linux-gnu (4:4.8.2-1) ... Removing gcc-4.8-aarch64-linux-gnu (4.8.4-2ubuntu1~14.04.1cross0.11.2) ... Processing triggers for man-db (2.6.7.1-1ubuntu1) ... Selecting previously unselected package gcc-multilib. (Reading database ... 617583 files and directories currently installed.) Preparing to unpack .../gcc-multilib_4%3a4.8.2-1ubuntu6_amd64.deb ... Unpacking gcc-multilib (4:4.8.2-1ubuntu6) ... Setting up gcc-multilib (4:4.8.2-1ubuntu6) ... -e Done. You're ready to go with Yocto build now umkhan@umkhan-VirtualBox:~/QorIQ/QorIQ-SDK-V2.0-20160527-yocto$ ls build_ls1046ardb downloads fsl-setup-env sources sstate-cache umkhan@umkhan-VirtualBox:~/QorIQ/QorIQ-SDK-V2.0-20160527-yocto$ . ./fsl-setup-env -m ls1046ardb Configuring for ls1046ardb ... /home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/build_ls1046ardb was created before. Back to build project /home/umkhan/QorIQ/QorIQ-SDK-V2.0-20160527-yocto/build_ls1046ardb. Nothing is changed.
Hello Muhammad Umair Khan,
It seems that the lib sqlite3 is missing on your machine.
Please refer to the following procedure to reinstall python on your host.
$ wget https://www.python.org/ftp/python/2.7.6/Python-2.7.6.tar.xz
NOTE: Python 2.7.3 and python 2.7.5 can be used as well
$ tar -xf Python-2.7.6.tar.xz
$ cd Python-2.7.6
./configure --prefix=/opt/python-2.7.6
$ make
$ sudo make install
Add new python path in PATH variable
$ export PATH=/opt/python-2.7.6/bin:$PATH
TIC
