Dear Sir,
Our customer used Pin tool for i.MX Ver_4.1 to plan and assign i.MX8M design.
He found it can't setting difference voltage about NVCC_NAND and NVCC_SAI5 .
example: NVCC_NAND => 1.8V, NVCC_SAI5 => 3.3V , tools show error
NVCC_NAND => 3.3V, NVCC_SAI5 => 1.8V , tools show error
We checked and don’t find any limit about NVCC_SAI5 and NVCC_NAND on i.MX8M documents.
Could you help confirm it?
Looks like in Your configuration there is an interface, where some signals
are powered by NVCC_NAND, but other signals are powered by NVCC_SAI5.
In such case both power voltages must be the same.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
