Special Purpose Register Address
Question asked by Akshara Prasad on Aug 19, 2018
Latest reply on Sep 12, 2018 by David Tosenovjan
Hello Support Team,
I also faced the issue which was described in one of the tickets raised few years back "MPC5602D Data flash issue".
https://community.nxp.com/thread/436288
It was regarding flash corruption. Once the flash is corrupted, I see '???????' in the debugger and it ends in infinite reset loops.
@Lukas Zadrapa : Reading through post, I got to know that, flash blocks needs to erased again.
I went through the pdf and software code which was attached by you. And I managed to understand bit.
Do you have this alogorithm implemented in C code?
One more question,if I want to implement this in C code, how can i get the address of special purpose registers like MCSRR0, MSR, MCSR etc.
I also went through the e200z759CRM pdf (i.e Core Reference Manual), but somehow I could not figure out the base address of those registers. Could you please help me out in this ? I also went through VLEPEM pdf also.
What does 'lis' 'stw' 'lwz' instruction meant by?
What does @h @l meant by?
asm (lis r30, (address)@h);              \
asm (ori r30, r30, (address)@l);         \
asm (lwz r31, 0x0(r30));
Thanks And Regards,
Akshara Prasad
