Is there any official driver using kStatus_UART_IdleLineDetected idle line interrupt on freeRTOS? It seems I need to modify the source code of the fsl_uart_freertos.c. Just don't like to do this and want to be more compatible with the official SDK. Thanks,
Hi Weichen:
Unfortunately we don't have such an official driver using kStatus_UART_IdleLineDetected idle line interrupt on freeRTOS. You need to implement this function by yourself.
