Uart setting
Uart setting
frank涛李
Hi NXP, After setting UART receiveing by function UART_TransferReceiveNonBlocking( ) with ring buffer,why sometimes the first data received in callback function of UART is '\0' (0x00) other than the first data the other MCU sended?Picture 1 attached shows the received data. Best regards, Frank
Robin_Shen
The same problem as Case Number 00175405, please refer the answer in the email.
