External capacitive load in Max supply current for IO (i.MX6 processor)
Question asked by Dhvanish Parekh on Aug 17, 2018
Latest reply on Aug 17, 2018 by igorpadykov
What should be the value considered for external capacitive load in Max supply current equation for i.MX6x processor described in datasheets?
See below details copied from the datasheet:
General equation for estimated, maximum power consumption of an IO power supply:
Imax = N x C x V x (0.5 x F)
Where:
N—Number of IO pins supplied by the power line
C—Equivalent external capacitive load
V—IO voltage
(0.5 xF)—Data change rate. Up to 0.5 of the clock rate (F)
In this equation, Imax is in Amps, C in Farads, V in Volts, and F in Hertz.
