What is Target_ID for MPC 8240/8245 using Code Warrior TAP and GDB Proxy command?
mdavis331
My team and I were able to correctly initialize and communicate with the Code Warrior TAP GDB proxy. We still need some assistance with a particular instruction. Specifically:
mon jtag_chain <myTarget_ID>
Where can I locate the correct myTarget_ID for MPC 8240 and MPC 8245?
Please refer to the following link for more context on specific question (if needed):
https://community.nxp.com/message/999148?commentID=999148&et=notification.mention#comment-999148
yipingwang
Hello Matthew Davis,
Please try to use the command "mon jtag_chain mpc8260".
In addition, please use the CCS from CodeWarrior 8.8 with Patch 8.8.6 applied.
TIC
mdavis331
Not able to verify because I can't find CodeWarrior 8.8 with Patch 8.8.6?
Where can I download this specific version?
