AIPS-Lite Writing peripheral registers
Question asked by Emmanuel Aguilasocho on Aug 16, 2018
Latest reply on Aug 31, 2018 by Diana Batrlova
Reading the reference manual for S32K148 I found the following
It is mention in the "Peripheral bridge (AIPS-Lite) memory map" section, since I'm new on this AIPS and I'm still investigation how it works.
From what I read my understanding is that all writes to peripheral buses are done trough AIPS except for the ones that use Private Peripheral Bus. Is this the case?If that is the case, does this means write-read always apply for for basically all peripheral register or if there is a way to avoid this?
Is it recommended to always do the write-read as a best practice for S32K platforms?
Regards.
