KEAZ128 TRK-KEA CAN_LDD can't transmit the message
Question asked by Weijie Zhang on Aug 16, 2018
Latest reply on Aug 20, 2018 by Robin_Shen
hello,
   Now I use the codewarrior10.7 as the IDE , JLink as the debugger , and the target board is TRK-KEA, I use the PE expert CAN_LDD to develop the CAN module, the problem is that mscan can transmit and receive the message in loop mode , but after I disable the loop mode ,then it can't enter the Tx_Interrupt any more , I have connected the CANAlyzer as the Can receiver, If you anybody met this issue please tell me why .
   I have found that the transceiver is in standby mode , and I have connect the corresponding pin , the transceiver exit the standby mode. but the CANAlyzer couldn't receive any message, and the code can't enter the Tx_Interrupt , please anybody help me ,  Thank you!
