Is there any way to write my program directly to flash using the Codewarrior BDM debugger. I am using a MC68332 with external flash chip (Atmel AT49F002N). However, I cannot seem to get codewarrior to lode to flash. The only way I can really access the flash is by using a config file (i.e and commands below to write to location 0x500):
writemem.b 0x5555 0xAA
writemem.b 0x2AAA 0x55
writemem.b 0x5555 0xA0
writemem.b 0x0500 0x44
Is there a way to configure the codewarrior target to load to flash (i.e. perfom flash write commands) when debugging?? Is there a flash driver somewhere??
