Can IMX6Q DDR CLK discontinuity cause EMC (test radiation) issues ?
tommyduan
Thanks for your reply!
We currently test radiation(EMC RE) beyond the specification!I find it DDR CLK Multiple of frequency!before,We use I.mx6dl,We don't find this question.Whether caused by DDR power switch?
Yuri
  My opinion is, that pauses in i.MX6 DDR clock should not provide significant EMC
issues. What is more reasonable - please try to vary MMDC and DRAM drive strength.
Yuri
tommyduan
Thanks for you replay!
Because DDR layout refer to your DEMO,so  we can't add other RES/FB in clk;Previously we used 6DL is OK,DDR CLK is 400MHZ;Can the clock be changed to 400MHZ for I.MX6Q,How can we  try to vary MMDC and DRAM drive strength.Best to reduce!
Yuri
Look at section 2.1.3 [SI (Signal Integrity) Consideration] of
Freescale i.MX6 DRAM Port Application Guide-DDR3
Yuri.
