IDE install problem!
Question asked by na fu on Aug 14, 2018
Latest reply on Aug 19, 2018 by na fu
Hi, I recently downloaded MCUXpresso. Unfortunately, after  I installed the IDE when I open it, the IDE completely crashes, can not be opened.The logfile is below:
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x54ffa814, pid=3552, tid=0x00001f18
# JRE version: Java(TM) SE Runtime Environment (8.0_111-b14) (build 1.8.0_111-b14)
# Java VM: Java HotSpot(TM) Client VM (25.111-b14 mixed mode windows-x86 )
# Problematic frame:
# C  [mshtml.dll+0x59a814]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x0237c400):  JavaThread "main" [_thread_in_native, id=7960, stack(0x00090000,0x00190000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x00000078
Registers:
EAX=0x2d4fc728, EBX=0x00000000, ECX=0x00000000, EDX=0x00000001
ESP=0x00189ee0, EBP=0x00189ee0, ESI=0x00000000, EDI=0x2d503948
EIP=0x54ffa814, EFLAGS=0x00210202
Top of Stack: (sp=0x00189ee0)
0x00189ee0:   00189f40 54bc973a ffffff00 00189f38
0x00189ef0:   00189f98 00000000 2d503968 00189f48
0x00189f00:   00000000 00000010 2d503948 00000000
0x00189f10:   54be86bb 00000000 00000020 00000000
0x00189f20:   5506b684 00000000 00000000 54d9b1e2
0x00189f30:   00000000 00000000 00000000 00000000
0x00189f40:   00189f64 54bc965c 00189f98 00000000
0x00189f50:   0066a3e8 00000000 0027cc01 54f0ca3c
Instructions: (pc=0x54ffa814)
0x54ffa7f4:   89 46 34 89 46 38 e8 7a fd fc ff 8b ce e8 c5 fd
0x54ffa804:   fc ff 8b c6 5e c3 90 90 90 90 90 8b ff 55 8b ec
0x54ffa814:   8b 41 78 83 ec 40 80 78 7a 00 0f 85 79 b7 ce ff
0x54ffa824:   ff 75 0c ff 71 74 ff 15 98 cb 90 55 8b e5 5d c2
Register to memory mapping:
EAX=0x2d4fc728 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0x00000000 is an unknown value
EDX=0x00000001 is an unknown value
ESP=0x00189ee0 is pointing into the stack for thread: 0x0237c400
EBP=0x00189ee0 is pointing into the stack for thread: 0x0237c400
ESI=0x00000000 is an unknown value
EDI=0x2d503948 is an unknown value
Stack: [0x00090000,0x00190000],  sp=0x00189ee0,  free space=999k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [mshtml.dll+0x16973a]
C  [mshtml.dll+0x16965c]
C  [mshtml.dll+0x8738e9]
C  [mshtml.dll+0xb753d6]
C  [jscript9.dll+0x7056e]
C  [jscript9.dll+0x233ab3]
C  [jscript9.dll+0x1bc8e1]
C  [jscript9.dll+0x1bcdaa]
C  [jscript9.dll+0x65d5e]
C  [jscript9.dll+0x70baf]
C  [jscript9.dll+0xaa758]
C  [jscript9.dll+0xaa714]
C  [jscript9.dll+0x676ac]
C  [jscript9.dll+0x77f88]
C  [jscript9.dll+0x2db037]
C  [jscript9.dll+0x2dad00]
C  [jscript9.dll+0x2b9c31]
C  [jscript9.dll+0x2b9a2d]
C  [swt-win32-4628.dll+0x11b12]
j  org.eclipse.swt.internal.ole.win32.COM.VtblCall(IIII[I)I+0
j  org.eclipse.swt.internal.ole.win32.IDispatch.GetTypeInfo(II[I)I+8
j  org.eclipse.swt.ole.win32.OleAutomation.<init>(Lorg/eclipse/swt/internal/ole/win32/IDispatch;)V+40
j  org.eclipse.swt.ole.win32.Variant.getAutomation()Lorg/eclipse/swt/ole/win32/OleAutomation;+31
j  org.eclipse.swt.browser.IE.execute(Ljava/lang/String;)Z+171
j  org.eclipse.swt.browser.IE$6.handleEvent(Lorg/eclipse/swt/widgets/Event;)V+154
J 2274 C1 org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/swt/widgets/Event;)V (532 bytes) @ 0x028a4e28 [0x028a4d70+0xb8]
j  org.eclipse.swt.widgets.Display.sendEvent(Lorg/eclipse/swt/widgets/EventTable;Lorg/eclipse/swt/widgets/Event;)V+12
j  org.eclipse.swt.widgets.Widget.sendEvent(Lorg/eclipse/swt/widgets/Event;)V+26
j  org.eclipse.swt.widgets.Widget.sendEvent(ILorg/eclipse/swt/widgets/Event;Z)V+73
j  org.eclipse.swt.widgets.Widget.sendEvent(I)V+4
j  org.eclipse.swt.widgets.Widget.release(Z)V+26
j  org.eclipse.swt.widgets.Composite.releaseChildren(Z)V+31
j  org.eclipse.swt.widgets.Canvas.releaseChildren(Z)V+42
j  org.eclipse.swt.widgets.Decorations.releaseChildren(Z)V+22
j  org.eclipse.swt.widgets.Shell.releaseChildren(Z)V+101
j  org.eclipse.swt.widgets.Widget.release(Z)V+40
j  org.eclipse.swt.widgets.Widget.dispose()V+23
j  org.eclipse.swt.widgets.Decorations.dispose()V+52
j  org.eclipse.swt.widgets.Shell.dispose()V+1
j  org.eclipse.ui.internal.browser.WebBrowserUtil.canUseInternalWebBrowser()Z+68
j  org.eclipse.ui.internal.browser.WebBrowserPreference.getBrowserChoice()I+22
j  org.eclipse.ui.internal.browser.DefaultBrowserSupport.createBrowser(ILjava/lang/String;Ljava/lang/String;Ljava/lang/String;)Lorg/eclipse/ui/browser/IWebBrowser;+86
j  org.eclipse.ui.internal.browser.WorkbenchBrowserSupport.createBrowser(ILjava/lang/String;Ljava/lang/String;Ljava/lang/String;)Lorg/eclipse/ui/browser/IWebBrowser;+9
j  com.crt.utils.gui.WelcomeView.show(Ljava/net/URL;)V+22
j  com.crt.utils.gui.WelcomeView.show(Ljava/lang/String;Z)V+330
j  com.crt.utils.gui.WelcomeView.show(Z)V+3
j  com.crt.utils.gui.WelcomeView.show()V+2
j  com.crt.quickstart.views.QuickstartView.<init>()V+15
v  ~StubRoutines::call_stub
V  [jvm.dll+0x15a895]
V  [jvm.dll+0x220bfe]
V  [jvm.dll+0x15a92e]
V  [jvm.dll+0x167178]
V  [jvm.dll+0x167521]
V  [jvm.dll+0x103e28]
C  [java.dll+0x3b3a]
j  sun.reflect.NativeConstructorAccessorImpl.newInstance([Ljava/lang/Object;)Ljava/lang/Object;+85
J 2226 C1 sun.reflect.DelegatingConstructorAccessorImpl.newInstance([Ljava/lang/Object;)Ljava/lang/Object; (9 bytes) @ 0x0288bd78 [0x0288bd50+0x28]
J 2225 C1 java.lang.reflect.Constructor.newInstance([Ljava/lang/Object;)Ljava/lang/Object; (87 bytes) @ 0x0288b988 [0x0288b8a0+0xe8]
j  java.lang.Class.newInstance()Ljava/lang/Object;+138
j  org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(Lorg/eclipse/core/runtime/spi/RegistryContributor;Ljava/lang/String;Ljava/lang/String;)Ljava/lang/Object;+128
j  org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(Lorg/eclipse/core/runtime/spi/RegistryContributor;Ljava/lang/String;Ljava/lang/String;)Ljava/lang/Object;+7
j  org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(Ljava/lang/String;)Ljava/lang/Object;+315
j  org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(Ljava/lang/String;)Ljava/lang/Object;+5
j  org.eclipse.ui.internal.registry.ViewDescriptor.createView()Lorg/eclipse/ui/IViewPart;+56
j  org.eclipse.ui.internal.ViewReference.createPart()Lorg/eclipse/ui/IWorkbenchPart;+16
j  org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(Lorg/eclipse/ui/internal/WorkbenchPartReference;)Lorg/eclipse/ui/IWorkbenchPart;+1
j  org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create()V+42
V  [jvm.dll+0x1673e3]
V  [jvm.dll+0x103cb3]
C  [java.dll+0x3b26]
j  sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+100
J 2279 C1 sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (10 bytes) @ 0x028aa540 [0x028aa510+0x30]
J 2280 C1 java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object; (62 bytes) @ 0x025a36d4 [0x025a3600+0xd4]
J 2285 C1 org.eclipse.e4.core.internal.di.MethodRequestor.execute()Ljava/lang/Object; (189 bytes) @ 0x028aa99c [0x028aa7e0+0x1bc]
J 2202 C1 org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(Ljava/lang/Class;Ljava/lang/Object;Ljava/lang/Class;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;Ljava/util/ArrayList;)V (354 bytes) @ 0x0287e974 [0x0287e620+0x354]
J 2202 C1 org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(Ljava/lang/Class;Ljava/lang/Object;Ljava/lang/Class;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;Ljava/util/ArrayList;)V (354 bytes) @ 0x0287e7a8 [0x0287e620+0x188]
J 2324 C1 org.eclipse.e4.core.internal.di.InjectorImpl.inject(Ljava/lang/Object;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;)V (216 bytes) @ 0x028c11c8 [0x028c0c70+0x558]
j  org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(Ljava/lang/Class;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;)Ljava/lang/Object;+348
j  org.eclipse.e4.core.internal.di.InjectorImpl.make(Ljava/lang/Class;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;)Ljava/lang/Object;+11
j  org.eclipse.e4.core.contexts.ContextInjectionFactory.make(Ljava/lang/Class;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+13
j  org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(Lorg/osgi/framework/Bundle;Lorg/eclipse/e4/core/contexts/IEclipseContext;Lorg/eclipse/e4/core/contexts/IEclipseContext;Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object;+169
j  org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(Ljava/lang/String;Lorg/eclipse/e4/core/contexts/IEclipseContext;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+90
j  org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(Ljava/lang/String;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+4
j  org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;Ljava/lang/Object;)Ljava/lang/Object;+118
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;Ljava/lang/Object;)Ljava/lang/Object;+21
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;Ljava/lang/Object;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+563
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$1.run()V+21
J 1853 C1 org.eclipse.core.runtime.SafeRunner.run(Lorg/eclipse/core/runtime/ISafeRunnable;)V (38 bytes) @ 0x027ecf28 [0x027ecf00+0x28]
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;Ljava/lang/Object;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+19
j  org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;Ljava/lang/Object;)Ljava/lang/Object;+181
...<more frames>...
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  sun.reflect.NativeConstructorAccessorImpl.newInstance0(Ljava/lang/reflect/Constructor;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;)Ljava/lang/Object;+168
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(Lorg/eclipse/e4/ui/internal/workbench/swt/PartRenderingEngine;Lorg/eclipse/e4/ui/model/application/ui/MUIElement;)Ljava/lang/Object;+2
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run()V+13
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;)Ljava/lang/Object;+15
j  org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;)V+113
j  org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(Lorg/osgi/service/event/Event;)V+87
J 2506 C1 org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run()V (17 bytes) @ 0x0291b880 [0x0291b850+0x30]
J 2305 C1 org.eclipse.swt.widgets.Synchronizer.syncExec(Ljava/lang/Runnable;)V (225 bytes) @ 0x028b6790 [0x028b6450+0x340]
J 2306 C1 org.eclipse.ui.internal.UISynchronizer.syncExec(Ljava/lang/Runnable;)V (163 bytes) @ 0x028b8188 [0x028b78f0+0x898]
J 2320 C1 org.eclipse.swt.widgets.Display.syncExec(Ljava/lang/Runnable;)V (37 bytes) @ 0x028bfda4 [0x028bfb70+0x234]
J 2308 C1 org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(Ljava/lang/Runnable;)V (26 bytes) @ 0x028b9b84 [0x028b9a50+0x134]
J 2474 C1 org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(Lorg/osgi/service/event/Event;)V (37 bytes) @ 0x0290ca10 [0x0290c960+0xb0]
J 2290 C1 org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(Lorg/osgi/service/event/Event;Ljava/security/Permission;)V (138 bytes) @ 0x028aba54 [0x028ab6f0+0x364]
J 2288 C1 org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(Ljava/lang/Object;Ljava/lang/Object;ILjava/lang/Object;)V (19 bytes) @ 0x027c1c18 [0x027c1b90+0x88]
J 501 C1 org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(Ljava/util/Set;Lorg/eclipse/osgi/framework/eventmgr/EventDispatcher;ILjava/lang/Object;)V (69 bytes) @ 0x025f7ba8 [0x025f7ae0+0xc8]
J 1267 C1 org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ILjava/lang/Object;)V (81 bytes) @ 0x027669c0 [0x02766780+0x240]
J 2174 C1 org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(Lorg/osgi/service/event/Event;Z)V (219 bytes) @ 0x02874c2c [0x02874810+0x41c]
J 2377 C1 org.eclipse.equinox.internal.event.EventComponent.sendEvent(Lorg/osgi/service/event/Event;)V (9 bytes) @ 0x028dd7fc [0x028dd7d0+0x2c]
J 2379 C1 org.eclipse.e4.ui.services.internal.events.EventBroker.send(Ljava/lang/String;Ljava/lang/Object;)Z (91 bytes) @ 0x028ddd80 [0x028ddc90+0xf0]
J 2329 C1 org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(Lorg/eclipse/emf/common/notify/Notification;)V (61 bytes) @ 0x028c8494 [0x028c8260+0x234]
J 1791 C1 org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(Lorg/eclipse/emf/common/notify/Notification;)V (44 bytes) @ 0x0272b038 [0x0272afb0+0x88]
j  org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;)V+119
j  org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;)V+112
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;Ljava/lang/Object;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+609
j  org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(Lorg/eclipse/e4/ui/model/application/ui/MElementContainer;)V+53
j  org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(Lorg/eclipse/e4/ui/model/application/ui/MElementContainer;)V+12
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;Ljava/lang/Object;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+603
j  org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(Lorg/eclipse/e4/ui/model/application/ui/MElementContainer;)V+2
j  org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;)V+24
j  org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(Lorg/eclipse/e4/ui/model/application/ui/advanced/MPerspective;)V+34
j  org.eclipse.e4.ui.model.application.ui.advanced.impl.PerspectiveStackImpl.setSelectedElement(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;)V+5
j  org.eclipse.ui.internal.WorkbenchPage.setPerspective(Lorg/eclipse/ui/IPerspectiveDescriptor;)V+348
j  org.eclipse.ui.internal.WorkbenchWindow.setup()V+803
j  sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j  java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+56
j  org.eclipse.e4.core.internal.di.MethodRequestor.execute()Ljava/lang/Object;+90
j  org.eclipse.e4.core.internal.di.InjectorImpl.inject(Ljava/lang/Object;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;)V+175
j  org.eclipse.e4.core.internal.di.InjectorImpl.inject(Ljava/lang/Object;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;)V+4
j  org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(Ljava/lang/Object;Lorg/eclipse/e4/core/contexts/IEclipseContext;)V+13
j  org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Lorg/eclipse/core/runtime/IAdaptable;Lorg/eclipse/ui/IPerspectiveDescriptor;Lorg/eclipse/e4/ui/model/application/ui/basic/MWindow;Z)Lorg/eclipse/ui/IWorkbenchWindow;+139
j  org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow()Lorg/eclipse/ui/IWorkbenchWindow;+171
j  com.crt.config.toolbar.TargetInfoContribution.addListeners()V+28
j  com.crt.config.toolbar.TargetInfoContribution.initialize()V+1
j  com.crt.config.toolbar.TargetInfoContribution.createControl(Lorg/eclipse/swt/widgets/Composite;)Lorg/eclipse/swt/widgets/Control;+210
j  org.eclipse.ui.menus.WorkbenchWindowControlContribution.delegateCreateControl(Lorg/eclipse/swt/widgets/Composite;)Lorg/eclipse/swt/widgets/Control;+2
j  org.eclipse.ui.internal.menus.CompatibilityWorkbenchWindowControlContribution.construct(Lorg/eclipse/e4/ui/model/application/ui/basic/MWindow;Lorg/eclipse/e4/ui/model/application/ui/menu/MToolControl;Lorg/eclipse/swt/widgets/Composite;)V+246
j  org.eclipse.e4.core.internal.di.InjectorImpl.make(Ljava/lang/Class;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;Lorg/eclipse/e4/core/di/suppliers/PrimaryObjectSupplier;)Ljava/lang/Object;+13
j  org.eclipse.e4.core.contexts.ContextInjectionFactory.make(Ljava/lang/Class;Lorg/eclipse/e4/core/contexts/IEclipseContext;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+24
j  org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(Lorg/osgi/framework/Bundle;Lorg/eclipse/e4/core/contexts/IEclipseContext;Lorg/eclipse/e4/core/contexts/IEclipseContext;Lorg/eclipse/emf/common/util/URI;)Ljava/lang/Object;+181
j  org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(Ljava/lang/String;Lorg/eclipse/e4/core/contexts/IEclipseContext;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+4
j  org.eclipse.e4.ui.workbench.renderers.swt.ToolControlContribution.createControl(Lorg/eclipse/swt/widgets/Composite;)Lorg/eclipse/swt/widgets/Control;+95
j  org.eclipse.jface.action.ControlContribution.fill(Lorg/eclipse/swt/widgets/ToolBar;I)V+2
j  org.eclipse.jface.action.ToolBarManager.update(Z)V+472
j  org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.subscribeTopicUpdateToBeRendered(Lorg/osgi/service/event/Event;)V+327
j  sun.reflect.GeneratedMethodAccessor4.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+40
j  org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler$1.run()V+7
j  org.eclipse.swt.widgets.Synchronizer.syncExec(Ljava/lang/Runnable;)V+99
j  org.eclipse.ui.internal.UISynchronizer.syncExec(Ljava/lang/Runnable;)V+91
j  org.eclipse.swt.widgets.Display.syncExec(Ljava/lang/Runnable;)V+33
j  org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(Ljava/lang/Runnable;)V+22
j  org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(Lorg/osgi/service/event/Event;)V+122
j  org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(Lorg/osgi/service/event/Event;Ljava/security/Permission;)V+66
j  org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(Lorg/eclipse/equinox/internal/event/EventHandlerWrapper;Ljava/security/Permission;ILorg/osgi/service/event/Event;)V+4
j  org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(Ljava/lang/Object;Ljava/lang/Object;ILjava/lang/Object;)V+15
j  org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(Lorg/osgi/service/event/Event;)V+3
j  org.eclipse.equinox.internal.event.EventComponent.sendEvent(Lorg/osgi/service/event/Event;)V+5
j  org.eclipse.e4.ui.services.internal.events.EventBroker.send(Ljava/lang/String;Ljava/lang/Object;)Z+84
j  org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(Lorg/eclipse/emf/common/notify/Notification;)V+54
j  org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(Z)V+34
j  org.eclipse.e4.ui.workbench.renderers.swt.ToolBarContributionRecord.updateVisibility(Lorg/eclipse/e4/core/contexts/IEclipseContext;)V+81
j  org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$5.changed(Lorg/eclipse/e4/core/contexts/IEclipseContext;)Z+29
j  org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(Lorg/eclipse/e4/core/internal/contexts/ContextChangeEvent;)Z+215
j  org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(Lorg/eclipse/e4/core/contexts/RunAndTrack;)V+25
j  org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processAddition(Lorg/eclipse/e4/ui/model/application/ui/menu/MToolBar;Lorg/eclipse/jface/action/ToolBarManager;Lorg/eclipse/e4/ui/model/application/ui/menu/MToolBarContribution;)Z+85
j  org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.generateContributions(Lorg/eclipse/e4/ui/model/application/ui/menu/MToolBar;Ljava/util/List;)V+76
j  org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContribution(Lorg/eclipse/e4/ui/model/application/ui/menu/MToolBar;Ljava/lang/String;)V+55
j  org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.createWidget(Lorg/eclipse/e4/ui/model/application/ui/MUIElement;Ljava/lang/Object;)Ljava/lang/Object;+47
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeChildrenHandler(Lorg/osgi/service/event/Event;)V+173
j  sun.reflect.GeneratedMethodAccessor7.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+40
j  org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(Lorg/osgi/service/event/Event;)V+61
j  org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(Lorg/eclipse/emf/common/notify/Notification;)V+5
j  org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(ILjava/lang/Object;)V+68
j  org.eclipse.emf.common.util.AbstractEList.add(ILjava/lang/Object;)V+48
j  org.eclipse.e4.ui.internal.workbench.ContributionsAnalyzer.processAddition(Lorg/eclipse/e4/ui/model/application/ui/basic/MTrimBar;Lorg/eclipse/e4/ui/model/application/ui/menu/MTrimContribution;Ljava/util/List;Ljava/util/HashSet;)Z+133
j  org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.addTrimContributions(Lorg/eclipse/e4/ui/model/application/ui/basic/MTrimBar;Ljava/util/ArrayList;Lorg/eclipse/e4/core/contexts/IEclipseContext;Lorg/eclipse/e4/core/commands/ExpressionContext;)V+199
j  org.eclipse.e4.ui.workbench.renderers.swt.TrimBarRenderer.processContents(Lorg/eclipse/e4/ui/model/application/ui/MElementContainer;)V+78
j  org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(Lorg/eclipse/e4/ui/model/application/ui/MElementContainer;)V+227
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run()V+238
j  org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j  org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(Lorg/eclipse/e4/ui/model/application/MApplicationElement;Lorg/eclipse/e4/core/contexts/IEclipseContext;)Ljava/lang/Object;+57
j  org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(Lorg/eclipse/e4/ui/model/application/MApplicationElement;)V+20
j  org.eclipse.ui.internal.Workbench$5.run()V+436
j  org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j  org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j  org.eclipse.ui.internal.ide.application.IDEApplication.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+105
j  org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+85
j  org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+82
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+105
j  org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+132
j  org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+265
j  org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+160
j  org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x2a9cac00 JavaThread "Worker-1" [_thread_blocked, id=7400, stack(0x2d670000,0x2d770000)]
  0x2a9c9800 JavaThread "EMF Reference Cleaner" daemon [_thread_blocked, id=7608, stack(0x2ce40000,0x2cf40000)]
  0x2a9c9000 JavaThread "Worker-0" [_thread_blocked, id=8176, stack(0x2cc40000,0x2cd40000)]
  0x2a9c8c00 JavaThread "Worker-JM" [_thread_blocked, id=7576, stack(0x2c250000,0x2c350000)]
  0x2aa76800 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=4392, stack(0x2b430000,0x2b530000)]
  0x29ef9c00 JavaThread "Resolver thread - Equinox Container: 2662247f-81be-4008-ba28-5d552db966ae" daemon [_thread_blocked, id=3532, stack(0x2b1b0000,0x2b2b0000)]
  0x2a16fc00 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=6732, stack(0x2b070000,0x2b170000)]
  0x29e45400 JavaThread "Refresh Thread: Equinox Container: 2662247f-81be-4008-ba28-5d552db966ae" daemon [_thread_blocked, id=7600, stack(0x2a630000,0x2a730000)]
  0x29e44c00 JavaThread "Start Level: Equinox Container: 2662247f-81be-4008-ba28-5d552db966ae" daemon [_thread_blocked, id=7548, stack(0x2a4f0000,0x2a5f0000)]
  0x29e44800 JavaThread "Framework Event Dispatcher: org.eclipse.osgi.internal.framework.EquinoxEventPublisher@69b199" daemon [_thread_blocked, id=7552, stack(0x2a3b0000,0x2a4b0000)]
  0x29e30800 JavaThread "Active Thread: Equinox Container: 2662247f-81be-4008-ba28-5d552db966ae" [_thread_blocked, id=6640, stack(0x2a270000,0x2a370000)]
  0x29e16800 JavaThread "Resolver thread - Equinox Container: 2662247f-81be-4008-ba28-5d552db966ae" daemon [_thread_blocked, id=7992, stack(0x2a170000,0x2a270000)]
  0x29e19400 JavaThread "Resolver thread - Equinox Container: 2662247f-81be-4008-ba28-5d552db966ae" daemon [_thread_blocked, id=7676, stack(0x293a0000,0x294a0000)]
  0x24bafc00 JavaThread "Service Thread" daemon [_thread_blocked, id=7876, stack(0x254a0000,0x255a0000)]
  0x24b7ac00 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=7568, stack(0x25360000,0x25460000)]
  0x24b76c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=8084, stack(0x25220000,0x25320000)]
  0x24b76000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=8064, stack(0x250e0000,0x251e0000)]
  0x24b56000 JavaThread "Finalizer" daemon [_thread_blocked, id=8040, stack(0x24f50000,0x25050000)]
  0x24b2fc00 JavaThread "Reference Handler" daemon [_thread_blocked, id=8036, stack(0x24e10000,0x24f10000)]
=>0x0237c400 JavaThread "main" [_thread_in_native, id=7960, stack(0x00090000,0x00190000)]
Other Threads:
  0x24b2a000 VMThread [stack: 0x24d10000,0x24e10000] [id=8028]
  0x24b81400 WatcherThread [stack: 0x255e0000,0x256e0000] [id=7632]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
 def new generation   total 39424K, used 25125K [0x04600000, 0x070c0000, 0x0f0a0000)
  eden space 35072K,  59% used [0x04600000, 0x05a49570, 0x06840000)
  from space 4352K, 100% used [0x06c80000, 0x070c0000, 0x070c0000)
  to   space 4352K,   0% used [0x06840000, 0x06840000, 0x06c80000)
 tenured generation   total 87424K, used 41616K [0x0f0a0000, 0x14600000, 0x24600000)
   the space 87424K,  47% used [0x0f0a0000, 0x11944380, 0x11944400, 0x14600000)
 Metaspace       used 31106K, capacity 32802K, committed 32896K, reserved 33152K
Card table byte_map: [0x04480000,0x04590000] byte_map_base: 0x0445d000
Polling page: 0x005e0000
CodeCache: size=32768Kb used=4960Kb max_used=4961Kb free=27807Kb
 bounds [0x02480000, 0x02960000, 0x04480000]
 total_blobs=2806 nmethods=2577 adapters=158
 compilation: enabled
Compilation events (10 events):
Event: 4.492 Thread 0x24b7ac00 2636             org.eclipse.e4.ui.css.swt.dom.ControlElement::getParentNode (24 bytes)
Event: 4.492 Thread 0x24b7ac00 nmethod 2636 0x02957c48 code [0x02957d60, 0x02957e68]
Event: 4.492 Thread 0x24b7ac00 2637             org.eclipse.e4.ui.css.core.impl.engine.RegistryCSSPropertyHandlerProvider::getCSSPropertyHandlers (92 bytes)
Event: 4.493 Thread 0x24b7ac00 nmethod 2637 0x02957f88 code [0x02958110, 0x029584c4]
Event: 4.494 Thread 0x24b7ac00 2638             org.eclipse.e4.ui.css.core.impl.dom.CSSStyleDeclarationImpl::findCSSProperty (44 bytes)
Event: 4.494 Thread 0x24b7ac00 nmethod 2638 0x029588c8 code [0x02958a10, 0x02958bc0]
Event: 4.499 Thread 0x24b7ac00 2639             org.eclipse.osgi.internal.serviceregistry.ServiceReferenceImpl::equals (36 bytes)
Event: 4.499 Thread 0x24b7ac00 nmethod 2639 0x02958d88 code [0x02958e90, 0x02958fb0]
Event: 4.541 Thread 0x24b7ac00 2641             org.eclipse.swt.internal.LONG::equals (36 bytes)
Event: 4.541 Thread 0x24b7ac00 nmethod 2641 0x02959448 code [0x02959550, 0x02959670]
GC Heap History (10 events):
Event: 1.843 GC heap before
{Heap before GC invocations=5 (full 0):
 def new generation   total 39296K, used 12550K [0x04600000, 0x070a0000, 0x0f0a0000)
  eden space 34944K,  23% used [0x04600000, 0x04e01818, 0x06820000)
  from space 4352K, 100% used [0x06c60000, 0x070a0000, 0x070a0000)
  to   space 4352K,   0% used [0x06820000, 0x06820000, 0x06c60000)
 tenured generation   total 87424K, used 22432K [0x0f0a0000, 0x14600000, 0x24600000)
   the space 87424K,  25% used [0x0f0a0000, 0x10688100, 0x10688200, 0x14600000)
 Metaspace       used 11589K, capacity 12287K, committed 12288K, reserved 12672K
Event: 1.880 GC heap after
Heap after GC invocations=6 (full 1):
 def new generation   total 39424K, used 0K [0x04600000, 0x070c0000, 0x0f0a0000)
  eden space 35072K,   0% used [0x04600000, 0x04600000, 0x06840000)
  from space 4352K,   0% used [0x06840000, 0x06840000, 0x06c80000)
  to   space 4352K,   0% used [0x06c80000, 0x06c80000, 0x070c0000)
 tenured generation   total 87424K, used 23951K [0x0f0a0000, 0x14600000, 0x24600000)
   the space 87424K,  27% used [0x0f0a0000, 0x10803cc8, 0x10803e00, 0x14600000)
Event: 2.590 GC heap before
{Heap before GC invocations=6 (full 1):
 def new generation   total 39424K, used 35072K [0x04600000, 0x070c0000, 0x0f0a0000)
  eden space 35072K, 100% used [0x04600000, 0x06840000, 0x06840000)
 Metaspace       used 17366K, capacity 18368K, committed 18432K, reserved 18816K
Event: 2.603 GC heap after
Heap after GC invocations=7 (full 1):
 def new generation   total 39424K, used 4352K [0x04600000, 0x070c0000, 0x0f0a0000)
 tenured generation   total 87424K, used 29419K [0x0f0a0000, 0x14600000, 0x24600000)
   the space 87424K,  33% used [0x0f0a0000, 0x10d5ac60, 0x10d5ae00, 0x14600000)
Event: 2.818 GC heap before
{Heap before GC invocations=7 (full 1):
 def new generation   total 39424K, used 23161K [0x04600000, 0x070c0000, 0x0f0a0000)
  eden space 35072K,  53% used [0x04600000, 0x0585e5b8, 0x06840000)
 Metaspace       used 19261K, capacity 20461K, committed 20480K, reserved 20864K
Event: 2.871 GC heap after
Heap after GC invocations=8 (full 2):
  from space 4352K,   0% used [0x06c80000, 0x06c80000, 0x070c0000)
 tenured generation   total 87424K, used 26699K [0x0f0a0000, 0x14600000, 0x24600000)
   the space 87424K,  30% used [0x0f0a0000, 0x10ab2e48, 0x10ab3000, 0x14600000)
Event: 3.520 GC heap before
{Heap before GC invocations=8 (full 2):
 Metaspace       used 24120K, capacity 25478K, committed 25600K, reserved 25984K
Event: 3.534 GC heap after
Heap after GC invocations=9 (full 2):
  from space 4352K, 100% used [0x06840000, 0x06c80000, 0x06c80000)
 tenured generation   total 87424K, used 33142K [0x0f0a0000, 0x14600000, 0x24600000)
   the space 87424K,  37% used [0x0f0a0000, 0x110fdac8, 0x110fdc00, 0x14600000)
Event: 4.236 GC heap before
{Heap before GC invocations=9 (full 2):
 def new generation   total 39424K, used 39424K [0x04600000, 0x070c0000, 0x0f0a0000)
 Metaspace       used 28531K, capacity 30165K, committed 30208K, reserved 31104K
Event: 4.255 GC heap after
Heap after GC invocations=10 (full 2):
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 3.181 Thread 0x0237c400 Exception <a 'java/io/FileNotFoundException'> (0x05787908) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 3.181 Thread 0x0237c400 Exception <a 'java/io/FileNotFoundException'> (0x057891c8) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 3.181 Thread 0x0237c400 Exception <a 'java/io/FileNotFoundException'> (0x0578a9f0) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 3.332 Thread 0x0237c400 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x05daba38) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 3.332 Thread 0x0237c400 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x05dacb80) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 3.754 Thread 0x0237c400 Implicit null exception at 0x028d22c4 to 0x028d2382
Event: 3.773 Thread 0x0237c400 Exception <a 'java/io/FileNotFoundException'> (0x0512f6f8) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 3.996 Thread 0x0237c400 Exception <a 'java/lang/ArrayIndexOutOfBoundsException'> (0x05cb76d0) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\runtime\sharedRuntime.cpp, line 605]
Event: 4.230 Thread 0x0237c400 Exception <a 'java/io/FileNotFoundException'> (0x067b8600) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\prims\jni.cpp, line 709]
Event: 4.400 Thread 0x0237c400 Exception <a 'java/io/FileNotFoundException'> (0x053ff7d0) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u111\7883\hotspot\src\share\vm\prims\jni.cpp, line 709]
Events (10 events):
Event: 4.507 loading class java/util/Observer done
Event: 4.507 Executing VM operation: RevokeBias
Event: 4.508 Executing VM operation: RevokeBias done
Event: 4.508 loading class java/util/Observable
Event: 4.508 loading class java/util/Observable done
Event: 4.511 Executing VM operation: Deoptimize
Event: 4.511 Executing VM operation: Deoptimize done
Event: 4.513 loading class org/eclipse/swt/browser/BrowserInitializer
Event: 4.513 loading class org/eclipse/swt/browser/BrowserInitializer done
Event: 4.541 Thread 0x24b7ac00 flushing nmethod 0x02640308
Dynamic libraries:
0x00400000 - 0x0044e000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\mcuxpressoide.exe
0x77090000 - 0x77210000     C:\Windows\SysWOW64\ntdll.dll
0x762f0000 - 0x76400000     C:\Windows\syswow64\kernel32.dll
0x75c50000 - 0x75c97000     C:\Windows\syswow64\KERNELBASE.dll
0x74790000 - 0x74890000     C:\Windows\syswow64\USER32.dll
0x75bc0000 - 0x75c50000     C:\Windows\syswow64\GDI32.dll
0x76400000 - 0x7640a000     C:\Windows\syswow64\LPK.dll
0x76190000 - 0x7622d000     C:\Windows\syswow64\USP10.dll
0x76240000 - 0x762ec000     C:\Windows\syswow64\msvcrt.dll
0x75b10000 - 0x75bb1000     C:\Windows\syswow64\ADVAPI32.dll
0x76980000 - 0x76999000     C:\Windows\SysWOW64\sechost.dll
0x75a20000 - 0x75b10000     C:\Windows\syswow64\RPCRT4.dll
0x74600000 - 0x74660000     C:\Windows\syswow64\SspiCli.dll
0x745f0000 - 0x745fc000     C:\Windows\syswow64\CRYPTBASE.dll
0x6d220000 - 0x6d3be000     C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.23403_none_2b180b30457f196c\COMCTL32.dll
0x76af0000 - 0x76b47000     C:\Windows\syswow64\SHLWAPI.dll
0x74a90000 - 0x74af0000     C:\Windows\system32\IMM32.DLL
0x760c0000 - 0x7618d000     C:\Windows\syswow64\MSCTF.dll
0x72000000 - 0x7200d000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.401.v20161122-1740\eclipse_1617.dll
0x74160000 - 0x74169000     C:\Windows\system32\VERSION.dll
0x56540000 - 0x5690d000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\jre\bin\client\jvm.dll
0x65030000 - 0x65037000     C:\Windows\system32\WSOCK32.dll
0x75d30000 - 0x75d65000     C:\Windows\syswow64\WS2_32.dll
0x76230000 - 0x76236000     C:\Windows\syswow64\NSI.dll
0x76770000 - 0x767a2000     C:\Windows\syswow64\WINMM.dll
0x74750000 - 0x74755000     C:\Windows\syswow64\PSAPI.DLL
0x6d650000 - 0x6d70f000     C:\Windows\system32\MSVCR100.dll
0x63ec0000 - 0x63ecc000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\jre\bin\verify.dll
0x60ce0000 - 0x60d01000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\jre\bin\java.dll
0x62580000 - 0x62593000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\jre\bin\zip.dll
0x74c60000 - 0x758ac000     C:\Windows\syswow64\SHELL32.dll
0x74b00000 - 0x74c5d000     C:\Windows\syswow64\ole32.dll
0x73d00000 - 0x73d0b000     C:\Windows\system32\profapi.dll
0x74130000 - 0x74147000     C:\Windows\system32\CRYPTSP.dll
0x740f0000 - 0x7412b000     C:\Windows\system32\rsaenh.dll
0x6f370000 - 0x6f389000     C:\Windows\system32\USERENV.dll
0x60d30000 - 0x60d46000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\jre\bin\net.dll
0x74170000 - 0x741ac000     C:\Windows\system32\mswsock.dll
0x6f1f0000 - 0x6f1f6000     C:\Windows\System32\wship6.dll
0x6f180000 - 0x6f19c000     C:\Windows\system32\IPHLPAPI.DLL
0x6f170000 - 0x6f177000     C:\Windows\system32\WINNSI.DLL
0x6e7b0000 - 0x6e7c2000     C:\Windows\system32\dhcpcsvc.DLL
0x6e7a0000 - 0x6e7ad000     C:\Windows\system32\dhcpcsvc6.DLL
0x63480000 - 0x6348f000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\jre\bin\nio.dll
0x6cce0000 - 0x6cd60000     C:\Windows\system32\uxtheme.dll
0x63b80000 - 0x63bcc000     C:\Windows\system32\apphelp.dll
0x25a00000 - 0x25f18000     C:\Windows\system32\SOGOUPY.IME
0x6d210000 - 0x6d215000     C:\Windows\system32\MSIMG32.dll
0x6d1d0000 - 0x6d20c000     C:\Windows\system32\OLEACC.dll
0x723b0000 - 0x723d1000     C:\Windows\system32\ntmarta.dll
0x759d0000 - 0x75a15000     C:\Windows\syswow64\WLDAP32.dll
0x76550000 - 0x765d3000     C:\Windows\syswow64\CLBCatQ.DLL
0x75930000 - 0x759c1000     C:\Windows\syswow64\OLEAUT32.dll
0x273d0000 - 0x274ad000     C:\Program Files (x86)\SogouInput\8.2.0.8853\Resource.dll
0x76740000 - 0x76753000     C:\Windows\syswow64\dwmapi.dll
0x637c0000 - 0x63955000     C:\Program Files (x86)\SogouInput\Components\PicFace\1.0.0.1562\PicFace.dll
0x63a60000 - 0x63a75000     C:\Program Files (x86)\SogouInput\Components\VoiceInput\1.0.0.139\VoiceInput.dll
0x6d4d0000 - 0x6d601000     C:\Windows\system32\WindowsCodecs.dll
0x2c450000 - 0x2c4be000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\configuration\org.eclipse.osgi\256\0\.cp\swt-win32-4628.dll
0x758b0000 - 0x7592b000     C:\Windows\syswow64\comdlg32.dll
0x64080000 - 0x640d1000     C:\Windows\system32\WINSPOOL.DRV
0x767c0000 - 0x7697d000     C:\Windows\syswow64\WININET.dll
0x76730000 - 0x76734000     C:\Windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll
0x77060000 - 0x77064000     C:\Windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
0x769b0000 - 0x769b4000     C:\Windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll
0x76760000 - 0x76763000     C:\Windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
0x75d20000 - 0x75d23000     C:\Windows\syswow64\normaliz.DLL
0x75da0000 - 0x75fb2000     C:\Windows\syswow64\iertutil.dll
0x769a0000 - 0x769a5000     C:\Windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
0x769c0000 - 0x76ae1000     C:\Windows\syswow64\CRYPT32.dll
0x767b0000 - 0x767bc000     C:\Windows\syswow64\MSASN1.dll
0x63bd0000 - 0x63cc5000     C:\Windows\system32\propsys.dll
0x2c4e0000 - 0x2c4fd000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\configuration\org.eclipse.osgi\256\0\.cp\swt-gdip-win32-4628.dll
0x6de80000 - 0x6e011000     C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.23721_none_5c052bcda00f9399\gdiplus.dll
0x2d240000 - 0x2d467000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\bin\dna.dll
0x629e0000 - 0x629ef000     C:\nxp\MCUXpressoIDE_10.0.0_344\ide\configuration\org.eclipse.osgi\131\0\.cp\jWinHttp-1.0.0.dll
0x63ad0000 - 0x63b28000     C:\Windows\system32\WINHTTP.dll
0x63a80000 - 0x63ad0000     C:\Windows\system32\webio.dll
0x63b70000 - 0x63b78000     C:\Windows\system32\credssp.dll
0x74760000 - 0x74787000     C:\Windows\syswow64\CFGMGR32.dll
0x60750000 - 0x6077e000     C:\Windows\system32\mlang.dll
0x62dc0000 - 0x62f30000     C:\Windows\system32\explorerframe.dll
0x652a0000 - 0x652cf000     C:\Windows\system32\DUser.dll
0x62d00000 - 0x62db2000     C:\Windows\system32\DUI70.dll
0x740e0000 - 0x740ee000     C:\Windows\system32\RpcRtRemote.dll
0x55aa0000 - 0x5653a000     C:\Windows\SysWOW64\ieframe.dll
0x623d0000 - 0x623d4000     C:\Windows\SysWOW64\api-ms-win-downlevel-shell32-l1-1-0.dll
0x63eb0000 - 0x63eb4000     C:\Windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll
0x76600000 - 0x76722000     C:\Windows\syswow64\urlmon.dll
0x760b0000 - 0x760b4000     C:\Windows\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll
0x6e6a0000 - 0x6e6ff000     C:\Windows\system32\SXS.DLL
0x54a60000 - 0x55a9b000     C:\Windows\SysWOW64\mshtml.dll
0x6ce90000 - 0x6ce98000     C:\Windows\system32\Secur32.dll
0x5dbc0000 - 0x5dfd4000     C:\Windows\SysWOW64\jscript9.dll
0x6cea0000 - 0x6cea4000     C:\Windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll
0x64410000 - 0x644fb000     C:\Windows\system32\dbghelp.dll
VM Arguments:
jvm_args: -Dosgi.requiredJavaVersion=1.8 -Xms128m -Xmx512m -XX:MaxPermSize=256M
java_command: <unknown>
java_class_path (initial): C:\nxp\MCUXpressoIDE_10.0.0_344\ide\\plugins/org.eclipse.equinox.launcher_1.3.201.v20161025-1711.jar
Launcher Type: generic
Environment Variables:
JAVA_HOME=C:\java8u161
PATH=C:/nxp/MCUXpressoIDE_10.0.0_344/ide/jre/bin/client;C:/nxp/MCUXpressoIDE_10.0.0_344/ide/jre/bin;C:/nxp/MCUXpressoIDE_10.0.0_344/ide/jre/lib/i386;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;D:\安装软件\SVN\bin;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Common Files\Sony Shared\FeliCaLibrary;C:\Program Files\Common Files\Sony Shared\FeliCaLibrary;C:\Program Files (x86)\Common Files\Sony Shared\FeliCaNFCLibrary;C:\Program Files\Common Files\Sony Shared\FeliCaNFCLibrary;C:\nxp\MCUXpressoIDE_10.0.0_344\ide;
USERNAME=SMC4130U20
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 78 Stepping 3, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows 7 , 64 bit Build 7601 (6.1.7601.23796)
CPU:total 4 (2 cores per cpu, 2 threads per core) family 6 model 78 stepping 3, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, avx2, aes, clmul, erms, 3dnowpref, lzcnt, ht, tsc, tscinvbit, bmi1, bmi2, adx
Memory: 4k page, physical 8266336k(4321920k free), swap 16530812k(12072308k free)
vm_info: Java HotSpot(TM) Client VM (25.111-b14) for windows-x86 JRE (1.8.0_111-b14), built on Sep 22 2016 18:54:33 by "java_re" with MS VC++ 10.0 (VS2010)
time: Wed Aug 15 13:50:00 2018
elapsed time: 4 seconds (0d 0h 0m 4s)
