Do not want auto suspend
wangtsungli
Hi community,
I'm working on i.MX6 Quad sabre-SD platform and build my image for Android 6.0.
Since my hardware design has no PMIC on it, I do a lot of work on uboot and kernel driver.
So far my machine can start server now but I face a new problem now.
After my machine booting success and get into system, my machine will auto suspend and cannot wake up again.
Below is log for suspend.
PM: suspend entry 1970-01-01 00:01:44.146406678 UTC
PM: Syncing filesystems ... done.
Freezing user space processes ...
PM: Wakeup pending, aborting suspend
active wakeup source: PowerManagerService.Broadcasts
Freezing of tasks aborted after 0.009 seconds
Restarting tasks ... done.
PM: suspend exit 1970-01-01 00:01:44.188327678 UTC
PM: suspend entry 1970-01-01 00:01:44.293293345 UTC
Freezing user space processes ... (elapsed 0.001 seconds) done.
Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Suspending console(s) (use no_console_suspend to debug)
PM: suspend of devices complete after 90.926 msecs
PM: suspend devices took 0.090 seconds
PM: late suspend of devices complete after 0.948 msecs
PM: noirq suspend of devices complete after 1.016 msecs
Disabling non-boot CPUs ...
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
Resume caused by IRQ 51
Suspended for 0.000 seconds
Enabling non-boot CPUs ...
CPU1 is up
CPU2 is up
CPU3 is up
PM: noirq resume of devices complete after 0.825 msecs
PM: early resume of devices complete after 0.512 msecs
usb 1-1: reset high-speed USB device number 5 using ci_hdrc
usb 1-1: device descriptor read/all, error -71
dpm_run_callback(): usb_dev_resume+0x0/0x10 returns -71
PM: Device 1-1 failed to resume async: error -71
PM: resume of devices complete after 632.085 msecs
PM: resume devices took 0.630 seconds
usb 1-1: USB disconnect, device number 5
done.
PM: suspend exit 1970-01-01 00:01:47.708025334 UTC
PM: suspend entry 1970-01-01 00:01:47.808199334 UTC
usb 1-1: new high-speed USB device number 6 using ci_hdrc
done.
usb 1-1: New USB device found, idVendor=0424, idProduct=2514
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
active wakeup source: NETLINK
Freezing of tasks aborted after 0.157 secondshub 1-1:1.0: config failed, can't read hub descriptor (err -22)
Restarting kernel threads ... done.
PM: suspend exit 1970-01-01 00:01:48.017854000 UTC
PM: suspend entry 1970-01-01 00:01:48.123030334 UTC
usb 1-1: reset high-speed USB device number 6 using ci_hdrc
usb 1-1: device firmware changed
usb 1-1: USB disconnect, device number 6
(elapsed 0.228 seconds) done.
Freezing of tasks aborted after 0.006 seconds
PM: suspend exit 1970-01-01 00:01:48.404555667 UTC
usb 1-1: new high-speed USB device number 7 using ci_hdrc
PM: suspend entry 1970-01-01 00:01:48.509662334 UTC
Freezing of tasks aborted after 0.143 secondshub 1-1:1.0: config failed, can't read hub descriptor (err -22)
PM: suspend exit 1970-01-01 00:01:48.699621001 UTC
PM: suspend entry 1970-01-01 00:01:48.804633001 UTC
PM: suspend of devices complete after 86.780 msecs
PM: late suspend of devices complete after 0.958 msecs
PM: noirq suspend of devices complete after 1.057 msecs
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
CPU1 is up
CPU2 is up
CPU3 is up
PM: noirq resume of devices complete after 0.903 msecs
PM: early resume of devices complete after 0.533 msecs
usb 1-1: reset high-speed USB device number 7 using ci_hdrc
PM: resume of devices complete after 347.815 msecs
PM: resume devices took 0.350 seconds
usb 1-1: USB disconnect, device number 7
done.
PM: suspend exit 1970-01-01 00:01:53.407441666 UTC
PM: suspend entry 1970-01-01 00:01:53.512178666 UTC
usb 1-1: new high-speed USB device number 8 using ci_hdrc
done.
usb 1-1: unable to read config index 0 descriptor/start: -32
usb 1-1: chopping to 0 config(s)
usb 1-1: no configuration chosen from 0 choices
(elapsed 0.158 seconds) done.
device_prepare(): pm_genpd_prepare+0x0/0x1f0 returns -16
PM: Device 2040000.vpu_fsl not prepared for power transition: code -16
PM: Some devices failed to suspend, or early wake event detected
PM: resume of devices complete after 0.002 msecs
cpufreq: cpufreq_resume: Failed to start governor for policy: d2716800
PM: resume devices took 0.000 seconds
PM: suspend exit 1970-01-01 00:01:53.753755333 UTC
PM: suspend entry 1970-01-01 00:01:53.858500666 UTC
PM: suspend of devices complete after 77.453 msecs
PM: suspend devices took 0.070 seconds
PM: late suspend of devices complete after 0.946 msecs
PM: noirq suspend of devices complete after 1.031 msecs
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
Resume caused by IRQ 58
CPU1 is up
CPU2 is up
CPU3 is up
PM: noirq resume of devices complete after 0.463 msecs
PM: early resume of devices complete after 0.494 msecs
usb 1-1: reset high-speed USB device number 8 using ci_hdrc
PM: resume of devices complete after 617.675 msecs
PM: resume devices took 0.620 seconds
usb 1-1: USB disconnect, device number 8
done.
PM: suspend exit 1970-01-01 00:06:45.688142667 UTC
PM: suspend entry 1970-01-01 00:06:45.792953000 UTC
usb 1-1: new high-speed USB device number 9 using ci_hdrc
done.
Freezing of tasks aborted after 0.147 seconds
PM: suspend exit 1970-01-01 00:06:45.989388334 UTC
PM: suspend entry 1970-01-01 00:06:46.094411667 UTC
Is that mean my machine get into suspend mode?
If it is how can I avoid it?
Why my machine cannot use debug port to send command after suspend and how can I wake it up?
Thanks in Advanced!
Labels (6)
Hi tsung
one can try to narrow down problem disabling low power mode with
adding kernel boot parameter enable_wait_mode=off, use maximum operating frequency
with CPUFREQ driver described in Chapter 23 CPU Frequency Scaling (CPUFREQ) Driver
attached Linux Manual, try to disable the bus frequency driver, described in sect.24.1.2
wangtsungli
I tried it when get into system.
But it still get into suspend mode.
And console still cannot work even I add no_console_suspend=1 on u-boot environment.
I tried to disabled the gpio_keys.c than get log like below.
PM: suspend entry 1970-01-01 00:00:34.956435337 UTC
Freezing of tasks aborted after 0.008 seconds
PM: suspend exit 1970-01-01 00:00:34.997838337 UTC
PM: suspend entry 1970-01-01 00:00:35.102658337 UTC
PM: suspend of devices complete after 89.080 msecs
PM: late suspend of devices complete after 0.930 msecs
PM: noirq suspend of devices complete after 0.940 msecs
CPU1: shutdown
CPU2: shutdown
CPU3: shutdown
Since I did not set any power key so cpu would not resume after suspend.
Still the same problem why system will get into suspend mode?
And how can I avoid it?
For kernel driver I disabled autosuspend, I think it shouldn't get into suspend by itself.
But it did!
How can I fix this issue?
Thanks in Advanced!
