I'm using the driver example of flexnvm_eeprom in SDk2.
and I need to change the size code of the EEPROM from 32bytes (mentioned in the demo : #define EEPROM_DATA_SET_SIZE_CODE (0x39U) ) to 3K.
How can I poursuit to change the size please?
Solved! Go to Solution.
Hi hayouni,
Please tell me what the kinetis chip you are using? Please tell me the chip part number.
I will help you to check it.
Actually, you can check that chip's reference manual, flash chapter, to check the partition content.
Kerry
Hi hayouni,
Kerry
Thank's Kerry,
I checked the reference manual and i m able now to change the data size code of the EEPROM partition.
