i used LTIB to rebuild a image that selected boa web server, and then i ran " run tftpramboot " but if this image size over 16MB , it didn't work after reloaded. Do you known another way to load image beside run command " run tftpramboot" ?
In the configuration of the BSP, you can select Boa Web server. Select this. Then rebuild the image, and you'll need to flash a new root filesystem to the board. There should be a document in the BSP that tells you how to do this.
