Clone Ubuntu image
Clone Ubuntu image
r_visserot
I have flashed an Ubuntu image on a board with the IMX7D (eMMC) and I did some change on it. What I would to do now it's to clone that image in order to flash it on an other board, but I don't know how to do it.
If you have a solution, I will be very glad to read it.
Thank you
Labels (2)
diegoadrian
Unfortunately, we cannot provide support related to Ubuntu, since it is a BSP that we do not provide. However, a way that you could try is using the dd command from all the mounted partitions, into your SD card that it was already partitioned the way you wanted, copying every information in their respective partition. Hope this can help and I apologize for the inconveniences this could take to you.
Diego.
