Hi, i wonder that whether i can build android image for i.mx6 duallite using YOCTO.
I found many reference about building android image for imx6, but they don't mentioned about using yocto.
Is it possible?
Here do not recommend you to use yocto to build the android images. About the android images build you can refer to our android userguide document.
Which version BSP are you using?
