We are using an lx2160ardb but u-boot version 2017.07 does not show the device.
mmc info reports no cards, however when we boot into linux, /dev/mmcblk1 is available with 128GB.
Any ideas why uboot does not report and how to fix this ?
Great. We'll try this ASAP.
Hello Markus Fischer,
I just confirmed with the Linux SDK testing team, the "mmc info" command works normally in u-boot provided in the latest LX2160A BSP v0.3 release.
You could require the access to LX2160A BSP v0.3 from the following link.
https://nxp1.sharepoint.com/teams/ext204/_layouts/15/AccessDenied.aspx?Source=https%3A%2F%2Fnxp1%2Es...
Please try the attached NOR flash u-boot image from BSP v0.3.
TIC
