I.MX8 board does not connect to serial using Hyperterminal
Question asked by Ankur Kala Employee on Aug 8, 2018
Latest reply on Aug 8, 2018 by Yuri Muhin
I have a i.mx 8M Quad evaluation kit and when I try to connect it through USB debug cable as mentioned in the QSG that comes with the board, the system does not recognize the serial ports. As such there is nothing observed over Hyperterm which is set as per the settings mentioned in QSG. The device manager also shows question marks against the ports assigned to the serial term.
Could you please let me know the driver required for the 'enhanced COM port' along with the version number.
Ankur
Ajesh Kumar
