Problem with Erase Flash memory
Question asked by luca.securo@bwtdyn.com on Aug 6, 2018
Latest reply on Aug 11, 2018 by luca.securo@bwtdyn.com
Hi to all,
I'm trying to read and write in flash memory with the new mkl33z64 microprocessor.
I had import an SDK flash's example for kl43. I had copy the function in my main I compiled it and it's ok.
I started to debug and the debugger stopped always during FLASH_Erase() inside the function ftfx_command_sequence(ftfx_config_t *config) in particular it stopped in this point: callFtfxRunCommand((FTFx_REG8_ACCESS_TYPE)(&FTFx->FSTAT));
This function is inside the driver fsl_ftfx_controller.c
I can't understand what happened. What's wrong?
Thank you for help.
Luca
