CW11 for S12 "internal compiler error"
Question asked by Marco Novaro on Aug 6, 2018
Latest reply on Aug 7, 2018 by ZhangJennie
I get the following compiler error
..\BSW\KERNEL\MCAL_S12x\mcu\Mcu.c:211: internal compiler error (report to
..\BSW\KERNEL\MCAL_S12x\mcu\Mcu.c:211: <cw_bug@freescale.com>)
..\BSW\KERNEL\MCAL_S12x\mcu\Mcu.c:211: while executing in file 'Coloring.c'
..\BSW\KERNEL\MCAL_S12x\mcu\Mcu.c:211: line: 698
..\BSW\KERNEL\MCAL_S12x\mcu\Mcu.c:211: (compiling 'Mcu_InitClock' in 'Mcu.c')
Trying to compile the a function for the S12 target. I’m using the following compiler version (mwccs12lisa):
CodeWarrior C/C++ for S12/L-ISA.
Copyright (c) 2017, Freescale Semiconductor, Inc
All rights reserved.
Version 5.0.44 (build 17292)
Runtime Built: Oct 20 2017 21:44:00
Using the default options provided by the project wizard (currently, no optimizations are on).
Any indication from your side about the cause of the error, and a possible workaround or fix, would be very welcome.
This issue is quite urgent for our development.
Thank you in advance, and best regards.
Marco
