FLASH ECC Error Injection on MPC5744P question
kai-hsiangtu
davidtosenovjan
Hello David,
I've try example project provide by S32DS about ECC error injection on MPC5744P and it works fine when I built it without optimization...
Once I try it with any kind of optimization, FCCU_Alarm_Interrupt and Machine_check_handler won't be trigger and the message window only show "End of MPC5744P ECC error test." after I select injection option.
How should I do if I need to implement this ECC feature with optimization build option?
Wally
Tags (2)
