When I build the project, several mistakes have been made. I guess it's a path allocation problem, so please give me some advice.Thank you!!
"C:/Freescale/CW MCU v11.0/MCU/DSP56800x_EABI_Tools/command_line_tools/mwasm56800e" @@"Utility/DSP56800E_promxram.args" -o "Utility/DSP56800E_promxram_asm.obj" "../Utility/DSP56800E_promxram.asm" -MD -gccdep
'Invoking: DSC Compiler'
"C:/Freescale/CW MCU v11.0/MCU/DSP56800x_EABI_Tools/command_line_tools/mwasm56800e" @@"Utility/DSP56800E_zeroBSS.args" -o "Utility/DSP56800E_zeroBSS_asm.obj" "../Utility/DSP56800E_zeroBSS.asm" -MD -gccdep
"C:/Freescale/CW MCU v11.0/MCU/DSP56800x_EABI_Tools/command_line_tools/mwcc56800e" -c @@"Sources/main.args" -o "Sources/main_c.obj" "C:/Users/15104/workspace/15W_MP/example/wct1013a/main.c" -MD -gccdep
"C:/Freescale/CW MCU v11.0/MCU/DSP56800x_EABI_Tools/command_line_tools/mwcc56800e" -c @@"Sources/lib/wct_LibParams.args" -o "Sources/lib/wct_LibParams_c.obj" "C:/Users/15104/workspace/15W_MP/example/wct1013a/lib/wct_LibParams.c" -MD -gccdep
"C:/Freescale/CW MCU v11.0/MCU/DSP56800x_EABI_Tools/command_line_tools/mwcc56800e" -c @@"Sources/lib/wct_libdata.args" -o "Sources/lib/wct_libdata_c.obj" "C:/Users/15104/workspace/15W_MP/example/wct1013a/lib/wct_libdata.c" -MD -gccdep
"C:/Freescale/CW MCU v11.0/MCU/DSP56800x_EABI_Tools/command_line_tools/mwcc56800e" -c @@"Sources/driver/FlexCAN.args" -o
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
系统找不到指定的路径。
mingw32-make: *** [Utility/DSP56800E_promxram_asm.obj] Error 1
mingw32-make: *** Waiting for unfinished jobs....
mingw32-make: *** [Utility/DSP56800E_zeroBSS_asm.obj] Error 1
mingw32-make: *** [Sources/main_c.obj] Error 1
mingw32-make: *** [Sources/lib/wct_LibParams_c.obj] Error 1
mingw32-make: *** [Sources/lib/wct_libdata_c.obj] Error 1
mingw32-make: *** [Sources/driver/FlexCAN_c.obj] Error 1
mingw32-make: *** [Sources/driver/adc_c.obj] Error 1
mingw32-make: *** [Sources/driver/cmp_c.obj] Error 1
mingw32-make: *** [Sources/driver/dac_c.obj] Error 1
mingw32-make: *** [Sources/driver/dma_c.obj] Error 1
mingw32-make: *** [Sources/driver/flash_c.obj] Error 1
mingw32-make: *** [Sources/driver/gpio_c.obj] Error 1
Hi HT,
It seems you didn't include full source code path in project path setting.
under Access Paths, please check if all your source code and include header file paths are added. for example, {path}/Sources/driver/
Jennie Zhang
